It is currently Sat Oct 24, 2026 7:48 pm
Post Posted: Sat Sep 22, 2012 12:20 pm
I am wrecking 2 x 1992 lwb vitaras.
Things of value to a Sierra will be mostly cheap and the rest will be free( as long as it is easy to remove)
1x auto base model no motor or auto
1x 5 speed with lecky windows. Motor is proberbly dead but most of the rest is there. Has a fair bit of suspension mods and when I first owned it had 33s on it.
Can post small things under 20kg at your cost and have access to cheap road freight through work.
Tell me what ya want and I will work out a price with freight. If anyone wants the body's then come and get them
Vehicle: '84 LWB 1LTR
Post Posted: Sat Sep 22, 2012 3:05 pm
PM'ED
Post Posted: Sat Sep 22, 2012 5:17 pm
I would love the doors bonnet and grills but that would cost a fortune!
Post Posted: Sat Sep 22, 2012 5:53 pm
Top bit of trim above the tailgate window and the driver's (master) window switch from the JLX?
Vehicle: 89 SWB vitara, g16b conversion
Post Posted: Sat Sep 22, 2012 7:40 pm
Pm'd mate
Vehicle: vits
Post Posted: Sat Sep 22, 2012 8:04 pm
The plastic trims off the doors on the JLX?
Post Posted: Sat Sep 22, 2012 8:15 pm
upper and lower rear coil mounts?
Vehicle: WT sierra, GU CRD
Post Posted: Sun Sep 23, 2012 12:04 am
Hi Shep,
Know its not the vits, but do you have a set of narrow track sierra flares?
Also
1.6 starter, 1.6 dizzy?
I love ZD30. :)
Post Posted: Sun Sep 23, 2012 8:35 am
do u have ALL the power steering components so i can fit to my sierra
Post Posted: Sun Sep 23, 2012 10:33 am
Yep and it looks great on my sierra :peaceout: be aware that everything needed for power steering on a Sierra isn't attached to a vitara other bits are needed.
I can't get at the 5 speed zook until next weekend, will check out trim bits and non Sierra friendly parts on the auto today and post pics.
Auto vit has no motor, auto, power steering, brakes, bonnet, drivers side door, shifter, console. Also I will be keeping the
5.12 fronts unless someone can swap for 4.3 to 4.6 r&p to fit a Sierra.
Vehicle: 1985 lwb 1.3 nt sierra
Post Posted: Sun Sep 23, 2012 11:03 am
Is the motor you have the g16b in the other? im chasing one to rebuild :)
Post Posted: Sun Sep 23, 2012 1:33 pm
Trim bit is broken. Won't know about switch until next weekend
Post Posted: Sun Sep 23, 2012 1:35 pm
I can't remember if they are there but if so and they are in ok cond you can have them
Post Posted: Sun Sep 23, 2012 9:11 pm
Buggritt. Maybe the other one will be OK? Will still grab switch off ya if it's all good and working.
Cheers,
Rob.
Users browsing this forum: No registered users and 51 guests
