It is currently Sat Oct 24, 2026 8:58 pm
Vehicle: 1.3 Tin Top
Post Posted: Mon Sep 24, 2012 2:19 pm
This week im doing my big project of body work, rust repair and some engine maitenance.
Im replacing the timing belt, water pump and rad.
HOW DO I GET THE CRANK AND CAM PULLEYS OFF??? (so i can replace the seals)
is there a trick???
Thank you in advance
Post Posted: Mon Sep 24, 2012 2:34 pm
Several, search for "crank pulley breaker bar".
Post Posted: Mon Sep 24, 2012 2:43 pm
THank you very much
Vehicle: LJ80
Post Posted: Mon Sep 24, 2012 2:51 pm
i used a piece of square tube with two bolts through it for the cam pulley
and a long bar plus the starter for the crank ( TIGHT )
Post Posted: Mon Sep 24, 2012 3:00 pm
Crank pulley, need a breaker bar about a meter long, put the car in 5th gear with handbrake on. Worked for me. You will also need a crank pulley remover tool thingy.
Post Posted: Mon Sep 24, 2012 3:03 pm
I used a $70 electric rattle gun off ebay, it did it easy. :)
Post Posted: Mon Sep 24, 2012 3:31 pm
I think I might leave it for the mechanic... will it hurt if i don't do the seals now?
Vehicle: LWB Sierra & XL7
Post Posted: Mon Sep 24, 2012 3:36 pm
Crank pulley, Loosie on the ground or chassis, an extention pipe over Loosie's handle usually does the trick and turn the key. (oh Loosie is what I call my breaker bar)
Rattle gun for the cam pulley.
Undoing the bolts is the hard part.
'92 Vitara & Camper trailer
Post Posted: Mon Sep 24, 2012 8:38 pm
Picture is inspiring but it will have to wait til I can get my hands on a rattle gun.
Vehicle: LJ80
Post Posted: Mon Sep 24, 2012 9:42 pm
rattle gun not needed for cam pulley
i use this and a socket they are welded but bolted will also work
Post Posted: Tue Sep 25, 2012 6:24 am
Have you got a FSM?
To remove the camshaft pully you put a screwdriver in a hole around cylinder No.2 of the camshaft. Hold it still while you use a spanner to undo the bolt.
SS
Post Posted: Tue Sep 25, 2012 11:13 am
thanks for all the help fella's
Vehicle: 1985 Holden Drover
Post Posted: Tue Sep 25, 2012 4:58 pm
DMAC wrote:
Have you got a FSM?
x2.
Its all in the FSM. Or just use a big podger if you dont have a screw driver big enough :)
Post Posted: Tue Sep 25, 2012 7:22 pm
Not in with all the lingo. FSM?
Post Posted: Tue Sep 25, 2012 8:05 pm
Service manual. :wink:
Post Posted: Wed Sep 26, 2012 8:45 am
Ahah i see :rofl:
Vehicle: Coily.
Post Posted: Wed Sep 26, 2012 10:28 am
Any Link,can only see A$129 +. TIA
Users browsing this forum: No registered users and 253 guests
