[ 7 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Thu Sep 27, 2012 9:45 am |
I'm not sure if the bits i'm talking about are called a retainer, but in the wheel bearing kits I have used the bearing is pressed on then the retainer is pressed on. The axle oil seal seals on the retainer.
So whatever it's called, can you buy these things separately?
_________________ SJ50.4.LYF
tanshi
 Posted: Thu Sep 27, 2012 9:48 am |
rear axle damo? any time ive bought new bearings they are included. tried CBC? EDIT: these?
BlueSuzy
 Posted: Thu Sep 27, 2012 9:53 am |
You should be able to buy them, or try and reuse.
The only thing that is sort of custom is the wt spacer using normal roller bearings. Ebay suppliers would get them made, all the rest would be on the shelf bits. Genuine style will have the step built in
weaves
Joined: Fri Mar 21, 2008 10:30 pm Posts: 1564 Location: Newcastle
 Posted: Thu Sep 27, 2012 12:03 pm |
014.MR is the part number i stock them under.
shouldnt cost much more than $5
_________________ I'm Weaver & i like beer, boobs, cars and stickers
Damo
 Posted: Thu Sep 27, 2012 12:15 pm |
That's the ones. I have one of Joe's rear disk setups which uses big GM bearings but you still need to run those retainers so I have to buy them separately.
coily96
Joined: Wed May 05, 2010 11:50 am Posts: 823 Location: Beenleigh
Vehicle: Coil Sierra
allied bearings nerang sells them for $5 they also do the whole bearing kit for $40 a side.
weaves
 Posted: Thu Sep 27, 2012 12:27 pm |
Allied never seem to have that stock for me when im chasing it.  Bearing wholesalers brisbane always has them - 07 3265 4144 - and if they don't, ask if you can pinch them out of 2617 kits.
[ 7 posts ] |
Users browsing this forum: Google [Bot] and 216 guests
