It is currently Sat Aug 01, 2026 1:56 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Thu Jun 30, 2011 1:25 am
Very nice right up :) would of been usefull to have this info when i rebuilt my front end but still very well done :)
Post Posted: Fri Jul 01, 2011 10:20 pm
Ive always done rubber tin felt tin and pulled many apart like that, is this why my diffs never wobbled or leaked?
:helloo: Don't know how the rubber was held in place, cause there is no lip or face for it in the hub, hence the first tin......
Post Posted: Fri Jul 01, 2011 10:55 pm
I bet ya never expected the length of this thread when you started, well done on the effort.
Did anyone mention the inside tins are at 90deg to outside tins so splits are against flat and a bit of sealant in split?
:helloo:
Post Posted: Fri Jul 01, 2011 11:50 pm
YEa!
Lil Foot!
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Fri Sep 28, 2012 9:25 pm
Hope this helps
seals etc to the right of diagram
Vehicle: Ducati Monster
Post Posted: Fri Sep 28, 2012 9:49 pm
so are the lowrange rebuild kits good quality or crappy? i guess it doesnt matter now since i ordered one yesterday anyhow
Post Posted: Fri Sep 28, 2012 10:43 pm
I'll be doing my first sierra swivel hub rebuild tomorrow. I bought a kit off eBay. $125 posted with all gaskets seals rubbers and koyo Japanese wheel bearings and king pin bearings.
How much is the lowrange kit cost ?
Post Posted: Fri Sep 28, 2012 11:10 pm
more than that :evil:
i needed some other stuff though too, guess that will teach me to shop around next time
Post Posted: Sat Sep 29, 2012 3:35 am
I think the low range kits are Koyo brand. The like using OEM quality.
Post Posted: Sat Sep 29, 2012 6:15 am
I'm just an eBay junkie.lol
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Sat Sep 29, 2012 6:46 am
Egay is king of cheap parts.
Just about everything on my Jimny has been replaced/rebuilt and about 80% is egay items!
Vehicle: 2018 DMAX
Post Posted: Sat Sep 29, 2012 7:19 am
The lowrange kit was ok, but I use the ebay spec ones now.. The oil seal, retainer, pad and cover felt pretty cheap on the lowrange kit.
Post Posted: Sat Sep 29, 2012 4:53 pm
carried out my swivel hub rebuild today. Wasnt too complicated. Just a lil time consuming. Got my discs machined at the same time. No more brake pulsation. Yay
Vehicle: Drover pickup turk
Post Posted: Wed Nov 07, 2012 2:53 pm
Pictures aren't working?
I like the tuna here
Vehicle: 1986 sj50 suzuki sierra
Post Posted: Wed Nov 07, 2012 5:13 pm
hey i left a post before about what i should do with my swivel hub if any one could help the post is just under this one
Vehicle: 2018 DMAX
Post Posted: Thu Nov 08, 2012 6:59 am
Yep, my host has changed something, will have to see if I can relink everything.
Vehicle: 84 stock as 1L sierra
Post Posted: Thu Dec 27, 2012 9:19 pm
hey mate. im having trouble with seeing the pictures..
any chance you have a photo-bucket account or something you can upload them too?
really in need off pic's cause this is my first big job to my suzi that im doing lol
Vehicle: 2018 DMAX
Post Posted: Fri Dec 28, 2012 10:53 am
I will relink the pics tonight.
Vehicle: 2018 DMAX
Post Posted: Fri Dec 28, 2012 6:40 pm
Pics relinked bar one.. Will see if I can find it. Original link below, maybe Royce knows where it went..
http://www.auszookers.com/modules/coppe ... torque.jpg
Vehicle: 91 sierra wt
Post Posted: Tue Sep 09, 2014 5:49 am
Hey guys thought I might ask here rather than starting a new thread!
I'm going to be having a crack at my swivel hub kit this weekend does anyone have any trick for bearing removal, or a tool that makes it easier old man suggested a slide hammer
Cheers partick
Post Posted: Tue Sep 09, 2014 6:50 am
For the races? The bearings themselves will just fall out. I normally just use a big screwdriver or a punch to knock out the races, just work your way around them.
Post Posted: Tue Sep 09, 2014 9:08 am
Ahhhhhhh okay beauty! Will the kit come with new races? And they just tap in correct?
Thanks for the quick reply
Post Posted: Tue Sep 09, 2014 10:45 am
Grind down one of the old races and use that to install the new ones.
Post Posted: Tue Sep 09, 2014 9:24 pm
Beauty thanks guys just received the kit today so il give it a crack on the weekend
Cheers Patrick
Post Posted: Wed Sep 10, 2014 5:23 pm
Great writeup but pics still don't work
Post Posted: Wed Sep 10, 2014 5:42 pm
That's strange all the pics are fine for me
Post Posted: Sat Sep 13, 2014 3:19 pm
Okay so I'm currently putting my passenger side back together been using this as a bible basically!
Now my problem is when I go to put my hub on the spline isn't sticking through far enough for the circlip to go back on?? Anyone able to shed some light on this?
Only thing can see that I did different is put my rubber tins and felt on before the hub!
Cheers Patrick
Post Posted: Sat Sep 13, 2014 10:43 pm
Screw a M8 bolt into the end of the axle and pull it outwards to fit the circlip. The CV/axle "floats", and the circlip locates the CV so the centre of it is aligned with the kingpin axis.
Post Posted: Sun Sep 14, 2014 12:04 am
^^^ that, should be the same thread as the FWH bolts?
Post Posted: Sun Sep 14, 2014 12:07 am
^^^ correct
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 219 guests
