It is currently Wed Oct 14, 2026 4:49 pm
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Tue Oct 02, 2012 5:29 pm
Just ordered some koyo front wheel bearings off eBay for my 91 Sierra. Just wondering if the inner and outer bearings ate the same? As I have 4 bearings that look identical?
Still yet to pull the old bearings out.
Post Posted: Tue Oct 02, 2012 6:07 pm
Yes. They are the same.
Post Posted: Tue Oct 02, 2012 6:32 pm
Thanks mate!
Post Posted: Tue Oct 02, 2012 7:59 pm
Another quick question what is the size of the nut that you torque up. Need to buy one for my torque wrench!
Post Posted: Tue Oct 02, 2012 8:01 pm
51mm IIRC. But I use a 55mm hilux one successfully, so it's not overly important.
Post Posted: Tue Oct 02, 2012 8:15 pm
My older brother is trying to argue that the correct way is doing em up tight then backing it off, sure it might work but it's guess work like this that sees bearings fail. The proper way is torqued up?
Post Posted: Tue Oct 02, 2012 8:26 pm
your brother is right, torque it up (while turning hub), undo, then torque up to a lower setting (again while turning hub), then torque up lock nut.
I don't know the torque specs, you'd have to check the fsm.
The idea is that it seats the bearings.
Post Posted: Tue Oct 02, 2012 8:30 pm
So I'm right! He said the old just do it up tight then back it off.
Post Posted: Tue Oct 02, 2012 8:36 pm
If I remember right.
Torque to 90lb. Loosen. Torque to 10-15lb? Put the lock washer on. Torque lock nut to 90lb. Fold tabs on washer.
Post Posted: Tue Oct 02, 2012 9:09 pm
And only fold ONE tab for each nut.
Users browsing this forum: No registered users and 246 guests
