It is currently Wed Jul 29, 2026 9:56 pm
Vehicle: Sierra Ute '87 Sj70
Post Posted: Tue Oct 02, 2012 5:32 pm
I found a vitara with a g16b in it for a sierra engine conversion.
What should I take?
How much should I expect to pay for a motor that blows a bit of smoke? (guy said it blows a bit of smoke)
Any other notes before I get it?
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Tue Oct 02, 2012 5:44 pm
Unless it is cheap I wouldnt get it. You can get low km jap vit engines from importers for $1400 iirc!
Post Posted: Tue Oct 02, 2012 6:12 pm
Rarer than rocking horse shit these days. The japanese G16B well has been pretty much tapped dry. And the new enviro laws; post Tsunami; are finishing off all of the small wrecking yards that may have held stock in the past.
So that leaves the Aussie delivered ones with 300K on them, or something else entirely. :(
Post Posted: Tue Oct 02, 2012 6:16 pm
Old mate said $250 but that's EVERYTHING (i was just wondering if that was cheap or not)
Post Posted: Tue Oct 02, 2012 6:18 pm
Thats cheap.
Price up a PROPER rebuild first though.
Post Posted: Tue Oct 02, 2012 6:29 pm
I could get one from springwood the other day? Could be gone by now. But yes they are getting rare!
Post Posted: Tue Oct 02, 2012 6:31 pm
So in answer to your orig post. Grab the engine, all engine loom, all other loom, dash. Ecu. If its swb grab the tank and pump. If u wanna go that way. Grab all the power steering stuff. And the accelerator cable.
Post Posted: Tue Oct 02, 2012 6:46 pm
Power steer is shageed it's seized
I got a ute and maybe able to work with the lwb tank
Post Posted: Tue Oct 02, 2012 6:50 pm
Still take everything, if everything else is fine all you will need is a new pump. Or you could sell the rest of the kit and get back money on it!
Vehicle: 89 SWB zuke
Post Posted: Tue Oct 02, 2012 7:40 pm
Payed $1500 for mine from cairns wreckers, unknown to me it didnt have MAF sensor (be sure to get this $150 on its own). you should get instrument cluster as mentioned, for speed sensor. And get the resistor condensor mounted to the firewall (or not, you may be the first to crack what value the resistor and two capacitors are inside it to make your own)
Post Posted: Wed Oct 03, 2012 6:30 pm
Got it home it's got oil coming out of the radiator hose but I can turn the flywheel over by hand
What could be the cause?
Post Posted: Wed Oct 03, 2012 6:56 pm
Probaly leaky head gasket or something similar I'd imagine. I think once u rebuild it, it will still work out a good buy.
Post Posted: Wed Oct 03, 2012 7:09 pm
Let's hope so.
Who can modify my sump and oil pick up?
Who can cut down my loom?
Post Posted: Wed Oct 03, 2012 7:57 pm
Any good auto sparky or killa kustom cables.
Anyone that can do brazing can do your pickup. The sump you just flog with a hammer!
Vehicle: 4wd
Post Posted: Wed Oct 03, 2012 8:00 pm
Sump and pickup shouldn't need any mods.
Watch out or you'll get sued.
Post Posted: Wed Oct 03, 2012 8:04 pm
To run the vit eng in the Sierra you have to use the Sierra sump to clear the diff housing which in turn means a hybrid oil pickup with vitara and Sierra. Unless you have moved your diff and have lift you can just use normal vit sump I think!
Post Posted: Wed Oct 03, 2012 8:09 pm
Correct.
And I prefer to TIG the oil pickup as opposed to brazing. Looks neater.
Post Posted: Wed Oct 03, 2012 8:11 pm
Correct.
You use see-through sumps? :wink:
Post Posted: Wed Oct 03, 2012 8:12 pm
JrZook wrote:
Correct.
No. But I can see the pickup before its fitted :wink:
Vehicle: 91 WT 1.6EFI
Post Posted: Wed Oct 03, 2012 9:30 pm
you can do the loom yourself. have a look at this.
viewtopic.php?f=5&t=34036&hilit=rossco%27s+guide
Post Posted: Thu Oct 04, 2012 5:24 pm
I called killer kustom kables he said $475 for the loom
Post Posted: Thu Oct 04, 2012 5:28 pm
Yep. I used one of his looms on a G16B swap recently. Fantastic to work with!
Post Posted: Thu Oct 04, 2012 7:38 pm
If my loom wasn't precut I'd happily pay that. Fuck the headache of wiring it up. And u will always know that the wiring was done properly!
Users browsing this forum: No registered users and 357 guests
