It is currently Fri Oct 09, 2026 7:39 pm
Post Posted: Wed Oct 03, 2012 3:56 pm
So ive been doing some searching around.
Some part numbers i have found for ARB side gear sets for various diffs are
728H081
728J081
Im hoping some one in the know, i.e Jowblow or some one else who has real world info can tell me if
the H / J etc has any real world relevance to axle shaft sizes or spline counts etc.
Post Posted: Wed Oct 03, 2012 6:14 pm
728H081
728J081
Plastic or steel pistons?
Post Posted: Wed Oct 03, 2012 7:21 pm
As far as I know the 'J' and 'H' designation is for size of the gear not including the spline. For example there may 10 versions of a 'J' sidegear with different splines. Your best bet is to tell me what spline count you are after including from what make and I will see if I can match something up for you.
Post Posted: Thu Oct 04, 2012 8:30 am
So the J gear is the same size and shape in all the lockers its used in, but has a different size spline through the middle?
IM looking at the possibilities of upsizing the spline and size of rear axles in a vit centre.
running full floats with bigger outers aswell
Post Posted: Thu Oct 04, 2012 8:31 am
728H081
728J081
these are later model lockers so not plastic i think
Post Posted: Thu Oct 04, 2012 9:06 am
from what i can find. 28.8mm or 30.8 shaft diameters.
any one got a vitara rear airlocker thay can measure the snouts of to see if either of those sizes will fit?
Users browsing this forum: No registered users and 148 guests
