It is currently Fri Sep 04, 2026 2:26 pm
Post new topic Reply to topic  [ 94 posts ]  Go to page 1, 2, 3, 4  Next
Vehicle: 1986 sj50 suzuki sierra
Post Posted: Wed Oct 03, 2012 7:51 pm
hey guys just did this slider design. its made up of 50x50mm box and the mounts are 50x5mm flat bar just wondering what everyone thinks!
Post Posted: Wed Oct 03, 2012 7:56 pm
needs moar triangulation, those mounts are going to bend like a mofo
Post Posted: Wed Oct 03, 2012 8:18 pm
X2.
And what are you bolting it to? Are you planning on drilling through the chassis? Hope not :?
Post Posted: Thu Oct 04, 2012 9:07 am
yer i was going to drill through the rail and im going to make the mount cup the rail too
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Thu Oct 04, 2012 9:32 am
Fatzook, how would you attach it to the chassis if you didn't drill through it???
The aftermarket ones I have been looking at for ideas all seem to bolt to the chassis.
Post Posted: Thu Oct 04, 2012 10:12 am
yer thats what i thought too all the one i have seen have bolted to the chassis how else would you do it any ideas
Post Posted: Thu Oct 04, 2012 10:21 am
they usually have a U clamp type set up to go around the chassis.
Post Posted: Thu Oct 04, 2012 10:26 am
U clamp yes... but with bolts going through the chassis. At least that's what I think the photos look like. I can't see any other way or securing the U clamp on there!
ie these ones:
http://www.lowrangeoffroad.com/index.ph ... -bars.html
harry loane, have you thought about using pipe instead of square tube? From my tafe courses ages ago it resists bending better. I think it looks nicer as well!
Post Posted: Thu Oct 04, 2012 10:51 am
yer your not wrong poita i will upload another picture of the the u cup that goes around the chassis im working on it now
Post Posted: Thu Oct 04, 2012 10:55 am
holes in chassis isn't the best idea without plating first IMO
Mr Fatzook knocked up some tidy mounts
Post Posted: Thu Oct 04, 2012 10:56 am
DO NOT drill through the chassis. Unless you know what you are doing ( ie qualified to do such work) it is dangerous and illegal.
FYI, nobody drills chassis rails for sliders over here. There are far easier ways to mount a slider.
If you want some of these, let me know.
Post Posted: Thu Oct 04, 2012 10:58 am
Same mount with gussets...
Post Posted: Thu Oct 04, 2012 10:59 am
can you make me some LWB ones Mr Fatfoot? :wink:
Post Posted: Thu Oct 04, 2012 11:00 am
Yeah. You have a B/L?
Post Posted: Thu Oct 04, 2012 11:01 am
yeah 2" BL from greg
Post Posted: Thu Oct 04, 2012 11:07 am
I'll see if Bigrig will let me borrow his LWB for a day.
what are some ideas then so this is int a good idea
Post Posted: Thu Oct 04, 2012 11:11 am
ok sweet thanks fatzook
Post Posted: Thu Oct 04, 2012 11:13 am
Some I made for Jason.
Post Posted: Thu Oct 04, 2012 11:20 am
how did you mount them?
Post Posted: Thu Oct 04, 2012 12:16 pm
Fatzook... your TSOR link in your sig isn't working.
Can you make them for a SWB Vit?
Post Posted: Thu Oct 04, 2012 12:25 pm
Thanks. I'll have a look at that.
I can make sliders for anything.
Here are some I did for an 80 series.....
Post Posted: Thu Oct 04, 2012 12:31 pm
so how do you mount them
Post Posted: Thu Oct 04, 2012 12:32 pm
Bolts over the top of the chassis rail:
GBW:
Mine:
Your second CAD is pretty much what we've done, but that lower bolt hole obviously won't work.
Post Posted: Thu Oct 04, 2012 12:35 pm
oh ok sweet so i could just make the mounts i have designed longer and run a bolt over the top
Post Posted: Thu Oct 04, 2012 12:44 pm
ill change the design and ill post another photo thanks heaps
Post Posted: Thu Oct 04, 2012 2:10 pm
Yep. ;)
Post Posted: Thu Oct 04, 2012 2:30 pm
this has the new mounts like what fatzook was talking about is this any better
Post Posted: Thu Oct 04, 2012 4:48 pm
Looks good to me ;) Don't forget some crush tube for the bolts so you don't squash your chassis rails.
You've measured to avoid crossmembers, brake line clips, body mounts etc yeah :lol:
Post Posted: Thu Oct 04, 2012 4:51 pm
Make your bracing bigger
Users browsing this forum: No registered users and 36 guests
