It is currently Sat Aug 01, 2026 7:35 am
Vehicle: 96 Sierra Tintop swb nt coily
Post Posted: Wed Oct 03, 2012 8:46 am
RIm going away in a couple of weeks and im looking at doing a major oil service.
Just seeing if theres any recommendations of brand to use from people who actually own these cars not some dodgy advice from a 16 year old at supercheap.
Vehicle: 2002 Suzuki XL7
Post Posted: Wed Oct 03, 2012 10:07 am
Penrite everyday plus 10-40w or Everyday 5-40W
Or if want full synthetic which lasts a tad longer go for HPR 10-40
If doing Gear oils, dif, transfer etc etc go for the Penrite Pro gear oil, most Autobarns have a Screen which recommends which Penrite oils to use. Also Repco can look it up.
I would stay away from Catrol Magnatech or mobile one and valvoline. I find only the penrite holds up when going off road.
This is what is recomended
Engine
HPR 30
Gearbox
GEAR OIL 80W-90
Transfer and Diffs
GEAR OIL 80W-90
Radiator
4 YR LONG DRAIN AFAB
Brake
DOT 3 BRAKE FLUID
Post Posted: Wed Oct 03, 2012 11:24 am
If you have lockers fitted apparently it's worth going for a specialised limited slip diff oil for them.
Otherwise an API GL-5 SAE 80W90 gear oil is the service manual recommendation.
Vehicle: Nl pajero Lwb, 98 jimny
Post Posted: Wed Oct 03, 2012 6:53 pm
I usually use castrol vmx80 but I really don't care as my diffs, transfer and gearbox oils get changed every couple of thousand kms.
Post Posted: Fri Oct 05, 2012 8:43 pm
How many litres will a standard diff n gearbox take?
Post Posted: Fri Oct 05, 2012 9:08 pm
the internet knows that answer http://www.datateck.com.au/lube/castr_au/
Post Posted: Sun Oct 07, 2012 7:18 pm
Problem solved. Cheers fellas
Post Posted: Sun Oct 07, 2012 7:29 pm
Interested to hear more about this! What does Penrite hold up that the others don't?
Post Posted: Mon Oct 08, 2012 8:27 am
Penrite uses alot more zink in their oils, also doesnt thin out as quickly as other oils, dont know the details about it, but the odd 170,000ks i have travled using all the main brands on the shelf except FUCH and Liqui Moli, penrite was the only one that didnt go water thin after a few thousand K's.
In previous cars i used Castrol Edge 5-40 which was a pretty good oil, kept the motor clean, and engine was quite revy using the stuff they now supposedly use liquid titanium, which is pretty new in engine oils.
Users browsing this forum: Google [Bot] and 71 guests
