It is currently Mon Aug 03, 2026 8:38 pm
Post Posted: Sun Oct 07, 2012 9:49 am
With my braking system. I have upgraded everything to make the brakes good and engineerable.
Now im thinking i will need another prob valve to suit the disc rear. I just don't know where to put it exactly :?
A B or C Position? Anyone have an idea? :?
Picture shows what i am using.
Thanks for any help :wink:
Post Posted: Sun Oct 07, 2012 9:52 am
Aren't prop valves un-engineerable?
Post Posted: Sun Oct 07, 2012 9:59 am
I know some engineered. Have to be boxed/hidden or not in easily adjustable reach.
*I'm also running coilovers*
Might even have to find a self load adjusting one yet. Havent spoken to engineer recently.
Post Posted: Sun Oct 07, 2012 10:11 am
+1
Post Posted: Sun Oct 07, 2012 10:40 am
It has to go on line "C". Aftermarket prop valves just limit the flow through the line, if you put it on either line before the sierra prop valve it will mess with how that valve works.
Would make positioning of it a lot easier to because it can be anywhere along the chassis rail.
Post Posted: Sun Oct 07, 2012 10:49 am
I was thinking C also.
Its a spidertrax type. But on they recomend put it up near the booster somewhere. (cant remember exact) They may have a slightly different braking system in the USA
My lines are all custom, But will work it out up the bum somewhere.
The original prop valve you can see just behind the transfer on the left, But my rear final line goes all the way up the back, and drops infront of the tank for the hose/bracket. Will work it out there somewhere. Bit of room to play.
Post Posted: Sun Oct 07, 2012 10:53 am
+1
I'l go back to my box then. :oops:
Post Posted: Sun Oct 07, 2012 11:31 am
Looks like the US use a different system. so wont be copying them
Post Posted: Sun Oct 07, 2012 2:43 pm
Is that pic a stock one? My guess would be they recommend putting it up near the booster if it's the only one in the system.
Piggybacking it onto a stock system with an exisiting self-adjusting one I reckon Zook_Fan is on the money.
Post Posted: Sun Oct 07, 2012 2:46 pm
The pic is stock US(?) they don't look the same on local cars.
Post Posted: Sun Oct 07, 2012 4:20 pm
Yes. Weird they use a different system!? This is for a twin line rear diff im guessing. Not sure if aussie twin rears ones are same?
http://www.suzuki-forums.com/suzuki-jim ... valve.html
Mine is a single line diff like most 90's sierras.
Post Posted: Sun Oct 07, 2012 4:24 pm
My original prop valve is very close to original spot.
I know some cruisers have prop valves bolted up next to the master
Post Posted: Sun Oct 07, 2012 4:39 pm
Yes, but only one valve in the system, yeah?
Post Posted: Sun Oct 07, 2012 4:49 pm
Yes like my drawing
Post Posted: Tue Oct 09, 2012 8:17 am
US Brakes are plumbed in a cross-over X pattern, where the front left wheel is plumbed with the rear right and the front right is plumbed to the rear left. Both circuits are identical. It's purportedly designed to prevent lock-up skids in snowy conditions.
Post Posted: Tue Oct 09, 2012 9:01 am
Ah ok. Tyring to contact engineer atm.
Post Posted: Tue Oct 09, 2012 10:16 am
Got hold of engineer.
Dont have to run the lux type bar load sensing. Its not a commercial vehicle.
Adjustable valves are engineerable.
Going to run Blue A line for front only
Moreon B/C line for rear only
The master is suited for discs anyway. All he said he is looking for is the front to lock up before the rear. Armsup
Post Posted: Tue Oct 09, 2012 10:01 pm
It has nothing to do with lock-up skids or snow - it is what is known as a "split-diagonal" system and it's purpose is to ensure that a leak does not cause total brake failure - a leak in either circuit will affect one front & one rear wheel only.
Users browsing this forum: Google [Bot] and 78 guests
