It is currently Mon Sep 21, 2026 4:03 pm
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3  Next
Vehicle: 2004 SQ625 GV
Post Posted: Fri Dec 24, 2010 4:44 am
Same as a lockright just different way of doing it.
Post Posted: Fri Dec 24, 2010 5:51 am
Yea just an expensive version of a Lockright. Only reason they can sell Lockrights is they're cheap, if you had to pay any where near as much as an air locker they won't sell many!
Vehicle: SJ410 ute
Post Posted: Thu Jan 20, 2011 2:16 am
have a look at this page for DIY diff locks
http://www.suzukiclubuk.co.uk/weldedreardiff.html
1lt , 4 spd, 30" treads, lockers
Vehicle: 2003 Jimny Auto
Post Posted: Mon Mar 26, 2012 10:03 pm
Digging out an old thread here
DOnt forget when locking to consider the effect it has on your ratios.
Open diff: Each wheel will turn at the same speed as the centre on average OR to put another way, the speed of the 2 wheels added together will ALWAYS equal twice the speed of the centre.
Auto locker: Inner/slower wheel will always match the centre. Outer/faster wheel can overrun thuis speed if on the ground or simply turn at same speed if in the air. So combined ratio may be faster than the centre. (ratio can vary with driving conditions)
Now consider what running different ratios in front compared to rear would do... Rear auto locker and front open diff = varying ratio rear, fixed front = drivetrain strain (at least) or lost traction due to rear trying to push the front faster that it wants to go on corners
Just an observation
Post Posted: Tue Mar 27, 2012 4:39 am
I see your point.
However, the biggest issue is the line each wheel takes through the turn. The front outside will do the most distance, then rear outside, then front inside, then rear inside.
Thus combined through a turn, the front travels slightly more distance.
(I guess theoretically it is posisble they cancel each other out at some point in time).
It has been advised to not have the car in 4wd/centre diff locked on high traction surfaces.
Post Posted: Tue Mar 27, 2012 9:40 am
Yeah.. If you don't need 4WD then don't use it.
Post Posted: Tue Mar 27, 2012 9:15 pm
Probably not for this thread, shoulda started another. So I have.
Big thankyou though to OP for the informative thread. Lockers are a fascinating bit of engineering (as is the humble differential itself actually)
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Tue Apr 03, 2012 5:13 pm
Can the electric lockers be bought for a 92 SWB vit? I tried finding some a while back but couldn't.
I'm a bit wary with the ARB lockers as 2 of my relatives have them and have had multiple seals fail on them.
Vehicle: 98' SJ80 lifted on 30s
Post Posted: Fri May 18, 2012 4:31 pm
Does anyone know a good LSD not a locker for a 98 SJ80 coil Sierra.
Vehicle: LJ20 LJ50
Post Posted: Fri May 18, 2012 5:41 pm
Kamdiffs
http://www.kamdiffs.com/vehicles/suzuki/
No!
Japanese make them but you would be looking around $1800AU fitted.
Camels have nice toes
Post Posted: Fri May 18, 2012 6:45 pm
Anyone know about these phantom grip LSD?
http://www.phantomgrip.com/index.php?pa ... t&Itemid=9
Post Posted: Fri May 18, 2012 7:11 pm
Looks great although...
1995-1998 SUZUKI JIMMY/SIDEKICK/SIERRA/VITARA (4X4 FRONT AND REA
Specifies only 4 year models and the jimny didnt start till 98, went through to current model virtually unchanged in the diffs. I have never seen a 95, 96 or 97 jimny... I think these years must have been a coily
As far as i know if it fits the aussie delivered 98 jimny it will fit all of them. But i wonder if this place is selling them for jimnys delivered elswhere and with (possibly) different diffs...
Post Posted: Fri May 18, 2012 8:01 pm
don't waste your money with the phantomgrip... the only grip it will have is on the money when you take it out of your wallet
Post Posted: Fri May 18, 2012 9:56 pm
:lol:
Post Posted: Sat May 19, 2012 1:41 am
A "Sierra" (SJ series Suzuki) is called a Jimny in Japan and other places. :wink:
But in short, yeah these guys are full of shit. :)
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Tue Jul 03, 2012 9:55 pm
hahaha i love the bloke that welded the pinion to the crown wheel haahah
If it ain't Broken, You ain't tryin hard enough...
Post Posted: Fri Sep 28, 2012 2:22 am
Stumbled upon this, whilst searching for something else.
http://www.billjohn.com/articles/drivetrain/kamelocker/kam.htm
Seems like a LOT of work, to install a locker.
Vehicle: LJ20 LJ50
Post Posted: Fri Sep 28, 2012 7:12 am
Pssst look up.
Posted: Fri, 18 May 2012 18:11:20 +0000
Kamdiffs
Post Posted: Fri Sep 28, 2012 8:09 am
Pssst look up.
Kamdiffs
It IS alot of work.
I have one here :wink: Will find its way into Rusho coily soon :twisted:
Post Posted: Fri Sep 28, 2012 9:47 am
I wish KAM would turn their "SJ410 sold out" to "in stock".
I think I'd need a change of pants if I could get locking LSDs for the LJ. :)
Post Posted: Fri Sep 28, 2012 11:55 am
Don't hold your breathe. KAM won't even return my emails. :roll:
Post Posted: Fri Sep 28, 2012 12:34 pm
Coz you're so special. :thefinger:
But yeah, they've never returned mine either. :|
I remember seeing a thread on a Niva forum where they got KAM to do a special run of 20 or so lockers for them for quite cheap (was about 650 pounds IIRC) so LJ/1l lockers certainly wouldn't be out of the question!
Vehicle: sj51
Post Posted: Fri Oct 05, 2012 11:22 pm
ox cable locker is another activation method too, but they are suited to dana style diffs
i ran them and they were super reliable
Vehicle: 2002 Suzuki XL7
Post Posted: Mon Oct 08, 2012 12:55 pm
Interesting subject :)
Ive been curious about Suzuki's Traction system that if one wheel looses traction it brakes that wheel so the one that has traction gets the power.
Ive seen this happen on my car with a video which i wish i could find doing donuts etc on mud, you could see each wheel pulsing trying to gain traction, and traction i had! i had full control over the car eg could flick it around and then drive forward with little loss of control, was amazed how much control i had.
Also wondered for this reason would i even need a locker? I had one front wheel in the air once and the other in the sand and both where spinning.
Vehicle: Vit
Post Posted: Tue Oct 09, 2012 9:43 am
That sounds cool gecko!
So for older vitaras like mine 97 would it be better to put a lock right locker in the back or front diff? I'm leaning towards the front so that it won't be engaged when doing on road driving and will only take effect when I engage 4wd, is this.correct thinking? What would u guys recommend?
Thanks ;)
Post Posted: Tue Oct 09, 2012 9:56 am
Yep in the front you have the correct thinking :)
If i went for a ARB locker they only make them for the front Diff.
Post Posted: Tue Oct 09, 2012 9:58 am
Thanks ;)
alloy front diff go bang. :(
some of the xl7's run a funny front diff from memory that is different to the vit/gv's
Vehicle: Vit
Post Posted: Tue Oct 09, 2012 10:07 am
Oh so the alloy diff is no good with a locker? What can happen, can't take the strain?
Post Posted: Tue Oct 09, 2012 10:17 am
the alloy housing is easily broken even unlocked, if your not going to build up a steel diff ($$$$) slap it in it's bum.
Vehicle: Vit
Post Posted: Tue Oct 09, 2012 10:28 am
Thanks Atari :)
Hmmmm ok then how would the back go with a lock right? Would it wear out the locker pretty quick? How badly does it effect on road driving?
Users browsing this forum: No registered users and 164 guests
