It is currently Tue Aug 04, 2026 7:10 am
Vehicle: SJ70
Post Posted: Tue Oct 09, 2012 5:43 pm
Hey guys,
Would appreciate some help doing my RUF.
Whatever i have tried my car still leans bad on the drivers side.
It sat fine with the 2inch front springs in. I have even tried putting my 2inch rears straight in with all leafs and it still sags alot.
What is the best combination of leafs to use and has anyone else had this happen?
Vehicle: Sierra
Post Posted: Tue Oct 09, 2012 6:30 pm
Did you cut the shackle hanger off and reweld it further forward? If so are you sure distances are the same left to right?
Have you taken it for a drive to settle it all in? You could add an extra leaf on driver side?
When I did my RUF I made the distance from spring hanger to shackle hanger about 1mm more on the drivers side (not sure if this is advisable) and placed the springs that were slightly more arched on the driver side. I have a slight passenger side lean with no one in the car and it sits level with me in the driver seat.
Vehicle: 4wd
Post Posted: Tue Oct 09, 2012 6:40 pm
Have you tried swapping left to right?
Watch out or you'll get sued.
Post Posted: Tue Oct 09, 2012 9:30 pm
I added an extra leaf to the driver side to allow for the extra weight. It's nice and level now, before it was shite.
Vehicle: SJ70
Post Posted: Wed Oct 10, 2012 11:33 am
No mounts moved but i am running extended shackles.
Put the 2inch rear straight up front.
what i had in there was 2 top leafs from the rears plus the 2nd leaf from the fronts.
This is now in the passenger side and as you can see in the 2nd pic it sits nice.
Vehicle: SJ70
Post Posted: Wed Oct 10, 2012 11:35 am
passenger side
Vehicle: '92 Sierra
Post Posted: Wed Oct 10, 2012 12:55 pm
Not really sure what you are describing with the leaf packs. Are you running an additional leaf in the driver side front or not? Like Damo I ran an additional leaf in my front DS pack to counter the lean when I went RUF.
Vehicle: SJ70
Post Posted: Wed Oct 10, 2012 1:33 pm
Yes i tried running an additional leaf from the old fronts. the 2nd leaf.
Or should i be using a leaf from another rear spring?
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Oct 10, 2012 4:10 pm
I'd try another rear, just guessing
Post Posted: Wed Oct 10, 2012 4:16 pm
oh you're back, i thought you took you bat and ball & left the last time you chucked a sooky sooky la la.... just guessing :wink:
Vehicle: SJ70
Post Posted: Wed Oct 10, 2012 5:11 pm
who chucked a sooky?
yeah tried with some different rears. They must all be shagged might try find some new rears.
Post Posted: Wed Oct 10, 2012 5:12 pm
KEENSY85 wrote:
U know Fuck the lot of u fucking smart as dick head and stick ur site up ur arse
Post Posted: Wed Oct 10, 2012 5:38 pm
Yep normally I'm a lot more chilled but you piss me off and unfortunately I'm not my normal, for that I must apologise
Post Posted: Wed Oct 10, 2012 7:10 pm
Damn right
Users browsing this forum: Google [Bot] and 245 guests
