It is currently Thu Sep 24, 2026 10:26 pm
Vehicle: '92 Sierra
Post Posted: Fri May 29, 2009 7:00 pm
I know this is done as part of a tune. I know it reduces engine noise too (tapity-tapity). But does it have any bearing on engine performance apart from damage caused by it being adjusted too tight?
Post Posted: Fri May 29, 2009 7:02 pm
Yes, it does. If the valves are too loose they won't open enough which will cause an airflow restriction through the cylinder.
Post Posted: Fri May 29, 2009 7:07 pm
Well too tight and the valves don't close fully, loss of performance. Mmmmmm too loose, increased tappet noise, extremely loose i don't know why you'd adjust them like that, but would result in valve opening stroke loss and hence performance losses. Id say likely hood of extreme damage would be very slim unless you are wayyy of the ballpark.
Anyone else?
Dan
Post Posted: Fri May 29, 2009 7:08 pm
You pretty nuch summed it up Dan
Post Posted: Sat May 30, 2009 12:07 am
a rattly tappet is a happy tappet :lol:
Post Posted: Sat May 30, 2009 12:17 am
the big thing is also valve opening duration, this can drop heaps so you lose power
on certain small pommie engines :wink: they reccomend first setting the tappets with a degree wheel to get the cam timing the same on all cylinders, then note down the different gap settings for future adjustments
Post Posted: Sat May 30, 2009 11:53 am
Won't this also burn out the valve seats?
Vehicle: '92 Sierra
Post Posted: Sat May 30, 2009 12:32 pm
Yeah that was the engine damage I was talking about. I thought I'd read too tight would burn them.
Though a degree wheel sounds fun I think it's probably slots into my "can't be farked" category. The old G16 is hardly a mini engine :P
Users browsing this forum: No registered users and 173 guests
