It is currently Tue Oct 20, 2026 3:12 am
Vehicle: 30s 2inch shackles sierra
Post Posted: Thu Oct 11, 2012 5:51 pm
hey fellow auszookers
I have replaced every bit of my cooling system, but the f10a still overheats.
Just wondering what the odds it could be a head gasket or head?
No water in oil or oil in water, but not sure if it could be the top end?
Vehicle: Yellow Ute
Post Posted: Thu Oct 11, 2012 6:02 pm
The only other ways the head gasket could break is between two cylinders and between a cylinder and a water jacket.
If it broke between a cylinder and water jacket it would over heat and your radiator would become pressurised and dump coolant everywhere.
Is your timing right? Sometimes if they are out of time (I forget which way) they can run hot.
Post Posted: Thu Oct 11, 2012 6:09 pm
cheers ill get my timing checked, if that's fine ill guess ill have to rip the head off i suppose
cheers
Post Posted: Thu Oct 11, 2012 6:31 pm
Is it loosing water
Did you replace thermostat
Did you replace water pump
Did you replace radiator
Is the fan on backwards
Is it overheating all the time
Is the sender working properly
Post Posted: Thu Oct 11, 2012 6:40 pm
2stroker wrote:
Is it loosing water
1 yes
2 yes
3 yes
4 fans on correct way
5 it only over heats when idling/crawling witch is a nascence
6 yeah it works replaced that to lol
any help will be good as im keen to get back out there
cheers
Vehicle: 4wd
Post Posted: Thu Oct 11, 2012 6:42 pm
norcorider wrote:
2stroker wrote:
Is it loosing water
1 yes
2 yes
3 yes
cheers
Did you replace the radiator?
Watch out or you'll get sued.
Post Posted: Thu Oct 11, 2012 6:44 pm
My guess is a leaky welsh plug. Mine was leaking under inlet manifold.
Left no signs, as heat kept it dry.
Hope it simple,
head jobs are no fun...well some are not
Post Posted: Thu Oct 11, 2012 6:45 pm
sorry stuffed that up abit
2stroker wrote:
Is it loosing water
1 no
2 yes
3 yes
4 yes
5 fans on correct way
6it only over heats when idling/crawling witch is a nascence
7 yeah it works replaced that to lol
cheers
Post Posted: Thu Oct 11, 2012 6:47 pm
Having the radiator stripped and cleaned is a good idea
Post Posted: Thu Oct 11, 2012 6:48 pm
PS. Inlet manifolds can crack, causing issues, though not common
Post Posted: Thu Oct 11, 2012 6:51 pm
cheers and radiator is brand new
Post Posted: Thu Oct 11, 2012 6:53 pm
How do you know that it's actually overheating? What is the coolant temp?
Post Posted: Thu Oct 11, 2012 6:56 pm
because it boiled twice, and reads over H on factory gauge, but i no they can be faulty
cheers
Post Posted: Thu Oct 11, 2012 6:59 pm
You need a pressure test, to see where coolant is going
Post Posted: Thu Oct 11, 2012 7:02 pm
yeah i going to do that to i think
Vehicle: 1.3 Tin Top
Post Posted: Thu Oct 11, 2012 8:51 pm
Just a thought...
Is there anything restricting airflow? like big lights, aircon stuff, big bar
Did u flush the system?
Have u got a shroud?
Post Posted: Thu Oct 11, 2012 8:54 pm
viscus fan clutch or solid ?
Post Posted: Thu Oct 11, 2012 9:43 pm
X2 fan, as it appears to be overheating at low speeds.
(Also be the cause of coolant loss from overflow when it boils.)
Fan shroud will help.
Check fan belt tension too.
Users browsing this forum: No registered users and 305 guests
