It is currently Tue Oct 20, 2026 12:53 pm
Post Posted: Thu Oct 11, 2012 11:23 pm
Exedy are all the rage apparantly. I looked at the pink Excedy HD, a bit pricey? Is it really necessary?
I need one pretty quick-ish.
Post Posted: Fri Oct 12, 2012 12:57 am
I always ran the $180 auto barn clutch, 2-3 years on each and still good :-)
Vehicle: LJ20 LJ50
Post Posted: Fri Oct 12, 2012 4:57 am
Get an old one rebuilt with some super bits added. Come on you know you want too. You cant get over those roundabouts and kerbs with just a standard clutch now can you.....
http://www.npcperformance.com.au/index.html
Camels have nice toes
Post Posted: Fri Oct 12, 2012 9:18 am
didn't Mr Knife like the clutch industries ones?
Post Posted: Fri Oct 12, 2012 9:51 am
Direct Clutch at Albion modified a excedy clutch pressure plate by adding extra spacer ring.
Increasing pressure applied to plate without extra tension on clutch cable, suppose to be similar
set-up to HD Excedy unit. Cost $200 from memory
Post Posted: Fri Oct 12, 2012 5:38 pm
I recommend Direct Clutch.
Helped me out with my Toyota-Suzuki clutch/pressure plate setup in my buggy.
Post Posted: Fri Oct 12, 2012 5:40 pm
I've never had an issue with CI ones
Users browsing this forum: Google [Bot] and 220 guests
