It is currently Tue Oct 20, 2026 11:27 am
Vehicle: LPG 1.6 Sierra
Post Posted: Fri Oct 12, 2012 12:40 pm
I'm making an adaptor plate so I can fit a 45mm throttle body to my manifold. I've used a jigsaw with an aluminium blade to get the general shape right, and I also bought a carbide burr bit which was apparently rated for aluminium use.
The burr bit is now clogged... I should have known it was going to happen, but I took the chance. Anyway - does anyone have a method of cleaning out ali from clogged bits?
Post Posted: Fri Oct 12, 2012 12:43 pm
wire wheel?
Vehicle: sj51
Post Posted: Fri Oct 12, 2012 12:45 pm
And use soap on the burr when using it
Vehicle: LJ20 LJ50
Scriber, wire brush then spray the thing with trefolox. will still clog up but not so quick.
Look here for the differnece pics of alloy vs steel. If you go to long it will just form a big alloy blob over the whole burr and you will be cursing all day.
http://www.sheffieldblades.com.au/burrs ... urring.pdf
Camels have nice toes
Post Posted: Fri Oct 12, 2012 2:45 pm
Wire wheel worked a treat. It seems slow and steady is the go - too much heat in the ali and it sticks to the bit like a mofo.
Post Posted: Fri Oct 12, 2012 4:13 pm
Armsup
Users browsing this forum: No registered users and 247 guests
