It is currently Sat Oct 31, 2026 8:57 pm
Post Posted: Sat Oct 13, 2012 2:14 pm
went for a drive up a hill today then back down, once i got to the bottom i tried to change back into 2wd and it wouldnt.
if wont go in 4h or 2wd, there is severe grinding noise in neautral. small wine in 4l.
i drove the hole way back home in 4l. the Transfercase was fine when i left home.
is my transfercase bugged?
Post Posted: Sat Oct 13, 2012 5:26 pm
Like a Sierra, check the bush...
Post Posted: Sat Oct 13, 2012 6:11 pm
You might also have wind-up if there wasn't enough loose ground to allow the wheels to slip (that's not well written, but I hope you get the idea). Wind-up will cause pre-load on the selectors and prevent them from sliding out of gear. To releive the pressure, reverse the car about a metre and try to shift into 2wd. If you've driven home a distance on sealed roads in 4wd, you MIGHT have buggered your case, but if it's still driving, you might be OK.
To release wind-up at home, jack up any one wheel. Then try to select 2wd. If this works, you are unlikely to have done long term damage.
Post Posted: Sun Oct 14, 2012 6:45 am
Ive tried driving in reverse, foward, flat ground, up hill, down hill, even on the bitumen.
I drove 60km/h for half an hour home. That was top speed with out going over 4000rpm.
Post Posted: Sun Oct 14, 2012 9:51 am
Failing what the other blokes have suggested.. it really really isnt hard to drop it out and open it up to have a look. thats a last resort obviously, but youll get an indication straight away if something is rooted in there.
MY BUILD THREAD HERE!!!!!
Post Posted: Sun Oct 14, 2012 7:14 pm
Are wt maruti transfercase gear set same ratio as wt 1.3l sierra gear set.
Its time to put in a sierra case i think, but all i have is a wt maruti case and wt flanges.
Post Posted: Mon Oct 15, 2012 8:09 am
The flanges may be interchangable.
Post Posted: Mon Oct 15, 2012 8:15 am
when i put my sierra case in, it was piss easy finding the case but hard finding flanges..... maybe have a look for a newer WT case? since you have the flanges already.
Post Posted: Mon Oct 15, 2012 9:49 am
Found one :)
Users browsing this forum: No registered users and 92 guests
