It is currently Sat Oct 24, 2026 9:45 pm
Post Posted: Sat Oct 13, 2012 5:13 pm
hey guys i was just wondering how do you drop out and change the oil in the transfer case? i cant seem to locate the buds? cheers.
Post Posted: Sat Oct 13, 2012 5:39 pm
Drain plug is at the bottom, filler bung is on the left side about halfway up. The bungs are designed for a 10mm square drive, but you may get away with a 3/8 ratchet.
Post Posted: Sat Oct 13, 2012 5:47 pm
yeah i did think that was them cheers, and also how much oil does it take? and what do use recommend cheers.
Post Posted: Sat Oct 13, 2012 6:00 pm
Just under a litre. I use Castrol EPX 80/90.
Post Posted: Sat Oct 13, 2012 7:05 pm
EPX 80W90 contains Sulphur and Phosphorus which can attack bronze components.
Definitely not the recommended oil for Sierra transfer case.
Use VMX-M 75W-85....
http://www.datateck.com.au/lube/castr_au/default.asp
Post Posted: Sat Oct 13, 2012 7:09 pm
what is bronxe in a tc? just for anyone looking at this thread haha
Post Posted: Sat Oct 13, 2012 7:15 pm
The counter shaft washers.
Post Posted: Sat Oct 13, 2012 7:19 pm
ah yes
Vehicle: 2011 jimny
Post Posted: Sun Oct 14, 2012 10:17 am
would EPX80-90 be alright to run in my jim transfer case?
Post Posted: Sun Oct 14, 2012 10:20 am
i use this as a guide http://www.datateck.com.au/lube/castr_au/
Post Posted: Sun Oct 14, 2012 10:21 am
I wouldn't...
Castrol ONLY recommend VMX-M for Suzuki transfers.... If EPX was OK I'm sure they'd list it too.
Vehicle: 2011 jimny
Post Posted: Sun Oct 14, 2012 10:27 am
thanks atari :D i think ill get a big bottle and change my gearbox to VMX looks like a more quality oil
Users browsing this forum: Google [Bot] and 179 guests
