It is currently Sun Oct 25, 2026 4:22 pm
Post Posted: Fri Oct 12, 2012 7:57 pm
Ongoing problem - After filling up the car with a full tank of petrol and doing a long trip on the highway and using about 3/4 of tank the car sometimes sound like it is starved of fuel and splatters.
When it first did this, I pulled over and I noticed the tank has sucked itself in a bit. As I took the petrol cap off I could feel suction on the cap, until the cap is off, then the tank makes a noise as it re-expands. This has happened about 10 times and every time it happens the tank is sucked in and by taking the cap of it fixes the problem.
Any ideas for a fix?
I am assuming some type of air intake for the tank is block. Where does the tank normally suck in air to replace the volume of fuel that the car uses? Cap, charcoal filter intake?
Post Posted: Fri Oct 12, 2012 8:00 pm
Charcoal canister is blocked.
Post Posted: Fri Oct 12, 2012 8:02 pm
sounds like you may have a blocked breather line. it will be one of the small pipes going to the fuel tank
Post Posted: Fri Oct 12, 2012 8:11 pm
yeah one of the previous owners had removed the charcoal canister for a dual battery tray and block off the pipe.
So does the charcoal canister's valving allow it act as a breather as well as a vent fumes?
Post Posted: Fri Oct 12, 2012 8:43 pm
Yes, it allows air to get in tank as fuel is used.
Needs to be there.
but as a temporary fix, leave cap loose.
Post Posted: Sat Oct 13, 2012 5:20 am
christover1 wrote:
I've had this problem for a couple of years on my Vitara.
I leave the cap loose as suggested.
I've checked the charcoal cannister and it is fine.
Just too mean to buy a new cap
Post Posted: Sat Oct 13, 2012 7:32 pm
i will defiantly try to chase up a second-hand charcoal filter. Anyone is Brisbane have a spare?
do some Suzuki fuel caps have vents on them? the springs on mine do look pretty rusty and there is dint in the outer rim of it. I see Suzistore sells spare ones. Do you think a new one will help?
Post Posted: Sat Oct 13, 2012 8:55 pm
My old 1.0 litre had a vented cap, but doubt it was factory.
it would leak out fuel on steep side slopes.
But a decent vented cap would help.
Vehicle: Vitara/LWB "ZOOKINI"
Post Posted: Sat Oct 13, 2012 11:24 pm
My Vit used to do this... Until I took a chunk out of the tank, solved the suction problem :lol: Curiously, the new tank doesn't do this, but when I undo the cap there is a vacuum as the air enters the tank, making me think that the problem may re occur. Be keen to know what fixes your issue.
Post Posted: Sun Oct 14, 2012 7:22 am
Start with a new cap.
If it still plays up, PM me and I'll send you the instructions on how to test your charcoal cannister.
Post Posted: Sun Oct 14, 2012 8:59 am
yeah might try new cap first and then find a charcoal canister and plumb it back in to where it has blanked out.
it would be good to find a fix. i think the tank is about 8L smaller due to being sucked in so often.
Post Posted: Sun Oct 14, 2012 9:45 am
actually i had a look at my fuel cap and i do not think the design has provisions for letting air in, only air out.
It looks like as pressure build in a tank it will push on the spring and as a result will slightly lift the cap.
Users browsing this forum: No registered users and 126 guests
