It is currently Tue Sep 22, 2026 7:59 am
Vehicle: 105 landcruiser
Post Posted: Sun May 31, 2009 1:26 am
transferred my good box and motor into my good vit... (has run 10 000 k without a hitch) the box has decided not to smoothly select out of 1st and second. it wont push into 3-4-5-and r
only yesterday it was running fine ..
is this a common prob or am i in big trouble... I'm gunna consult Manuel and see what he says just wondering if anyone had any ideas?
thanks
Fluff
Vehicle: 75 Cruiser
Post Posted: Sun May 31, 2009 1:31 am
not something simple like the usual sierra issue of stuffed gear stick bushes?
Post Posted: Sun May 31, 2009 1:43 am
it does go over to the 3-4 slot but its hard, and it does go into 5-r but its harder. feels like its stuck
Post Posted: Sun May 31, 2009 12:38 pm
Damaged detent ball :?:
Post Posted: Sun May 31, 2009 8:38 pm
hard with engine off or hard with running and foot on clutch?
Post Posted: Sun May 31, 2009 9:08 pm
both
Post Posted: Sun May 31, 2009 9:27 pm
got the stick in properly? its pretty easy to think its on right but isnt
Post Posted: Sun May 31, 2009 9:36 pm
if the stick is in right it will be either a clutch, pressure plate or cable problem. your firewall is not cracked?
Post Posted: Sun May 31, 2009 11:24 pm
found it..
while removing box from donor.. the bush found its way behind the gear shift arm.
when it was installed in the recipient. i had the bush from the previous box on the dash..
couldn't see it will i removed the shift lever case... and dismantled it.
ughh
*headbutts wall*
all good now
cheers fellas
Users browsing this forum: No registered users and 205 guests
