It is currently Sat Oct 31, 2026 10:14 pm
Vehicle: Suzuki Sierra 1997
Post Posted: Fri Oct 12, 2012 10:58 am
So I am getting over the ridiculously hard ride in my coily sierra. Does anyone have any experience with different springs for the coily sierra? can someone tell me what some "good" spring rates are? Just replaced the front 2 shocks thinking this would help this but no improvement, except they no longer clunk about now :P
Can anyone even tell me what the standard spring rate was for the coily sierra?
I have a 2.5" lift (suspension) from memory.
Thanks for any info anyone can give.
Vehicle: SJ80, SE416
Post Posted: Fri Oct 12, 2012 6:24 pm
How much weight are you carrying?
My Pedders springs are harsh but ride great when loaded close to GVM.
How much air in your tyres?
Vehicle: chick magnet coily
Post Posted: Sat Oct 13, 2012 7:47 am
Ive got the bluepac springs and they are quite soft and there quite cheap
also try running about 20psi in your tyres
Post Posted: Sun Oct 14, 2012 12:40 pm
Weight - Just standard usually empty car, no bull bar or roll bars or anything else heavy. Even with a full car most of the weight is over the back wheels and you can tell it makes and improvement in ride but this never really helps the front.
Tyre Pressure - I'm not convinced one should have to run lower pressures and increase tyre wear to "fix" suspension problems. But yes I have lowered pressures down to 18psi on a dirt track just because it was terribly unbearable.
@Fully Sick, I thought the bluepac stuff actually used king springs??? do you know what spring rates they are?
Post Posted: Sun Oct 14, 2012 1:03 pm
that theory is all well & good in a passenger car, but essentially you're dealing with a cart that has square wheels & no suspension.... tyre pressures will make a hell of a difference & 18psi isn't low, what pressures are you running on the road?
Post Posted: Sun Oct 14, 2012 1:50 pm
I run 20psi on road, anything down to 8 off road. Never had a problem with horse suspension in my coily, for a while there I was running the cheap eBay lift kit as well
Post Posted: Sun Oct 14, 2012 6:24 pm
X2.
:roll: :roll: :roll: :roll: :roll: :roll: :roll: :rofl: :roll: :roll: :roll: :rofl: :rofl: :rofl: :rofl: :roll: :lol: :rofl: :rofl: :rofl: :rofl: :rofl: :roll:
Running correct tyre pressure as per the tyre placard is the correct thing to do and will not increase tyre wear.
Try 20PSI - otherwise go and live with your harsh suspension - any springs too light as to actually give a nice ride with excessive tyre pressures will sag really quickly and give lots of body roll...
I had the off-the-shelf lifted King Springs in one of my coilies and they were alright but definitely sat a bit lower when loaded - they might suit an unloaded car, but you will need to run correct tyre pressures or they too will be harsh.
Vehicle: Coily "Ute"
Post Posted: Sun Oct 14, 2012 7:59 pm
I have a set of the king springs/ultima in my coily and run 20 PSI in 215/75 tyres and the ride isnt great but it isnt bad.
I used to run 25psi and it sucked. i found even 22psi was too much.
Post Posted: Sun Oct 14, 2012 8:04 pm
sounds like he must be friends with this fella
klutched wrote:
I normally run 40 psi
Post Posted: Mon Oct 15, 2012 8:50 am
40psi would be like driving a forklift with steel casters
Post Posted: Mon Oct 15, 2012 11:05 am
I am currently running 28front 26rear, and getting good even wear on the tyres. I will try the recommended 20psi and see how that goes I suppose. I still think the springs are wrong for the vehicle mass though, surely springs could be softer expecially in the front where mass over the wheels is not going to change all that much, I currently have next to no body roll whatsoever. Thank for the tips anyways guys.
Users browsing this forum: Google [Bot] and 77 guests
