It is currently Sun Oct 25, 2026 11:41 am
Vehicle: 89 SWB vit
Post Posted: Fri Sep 21, 2012 10:50 am
Hi Everyone!
So after 2 flat batteries i've still not learnt to turn my headlights off when i get out the car...thank for bump starts!
I've done a google search which only came up with overseas results.
From what I read it sounded like vitara's did have the 'hey dumbarse your headlights are on again' buzzer.
Firstly does anybody actually have it in their vitara or did AUS miss out?
If they do where is it located and what does it look like? I'm not sure if mine's just not working or been ripped out.
Thanks for your help :)
Vehicle: SJ51T
Post Posted: Fri Sep 21, 2012 11:13 am
I had one in my 91 SWB vitara. no idea where its located.
Vehicle: SJ80, SE416
Post Posted: Fri Sep 21, 2012 11:20 am
My JLX VItara has a headlight buzzer. It doesn't always work as the door switches in mine are worn out (doesn't help that the previous owner wired 2 fluoro lights through them).
Not too hard to make your own headlight buzzer.
Vehicle: Vit swb 95
Post Posted: Fri Sep 21, 2012 2:05 pm
I have a 1995, Buzzer works on and off.. (makes it worse) i check my lights EVERYTIME i hop out now, mad it a habbit haha
As Reubs said, make one?
Post Posted: Sat Sep 22, 2012 5:39 pm
My jx has one, nfi if factory or not
Easy as to fit though, get one from supercheap or wherever, power side to the dash light circuit, earth side to the power feed into the cigarette lighter socket, both wires can be accessed at the socket
then if the lights are on but key off it will buzz, door switches working or not.
Vehicle: 89 SWB vit
Post Posted: Sat Sep 22, 2012 9:25 pm
thanks for all the info everyone.
What do the buzzers look like and where under the dash is it normally?
Royce, that sounds like my best option. I've gotta suss out my door switches because they're not working, so atleast the buzzer would still work :)
Post Posted: Sat Sep 22, 2012 9:44 pm
get a door switch working first to see if you have a factory buzzer, just pull a door switch out and earth the wire coming out to the body, that will simulate what would happen when the door is open, then turn the lights on and see if it buzzes :)
Post Posted: Mon Oct 01, 2012 2:12 pm
why dont you buy one of the kits that turn your lights off when you turn ignition off like a subaru. or if your alright at wiring you could probably do it yourself. my 94 estate has a buzzer but door switches dont always work.
Vehicle: 89 SWB vit
Post Posted: Tue Oct 23, 2012 11:06 am
Thought i better get back to this one!
Earthed the drivers side wire to the body but nothing happened, no buzzer. Yes, i had the headlights on! :)
Passenger side works perfect, door opens interior light comes on. Drivers side wiring may be screwed somewhere, when the doors open interior lights not coming on.
Might go with Royce's suggestion and buy a buzzer kit...and then sus out why my interior lights not working! I think I need an Auto eleccy to adopt me!
Post Posted: Tue Oct 23, 2012 11:17 am
could just be a dicky door switch, pull it & give it a blast with CRC/WD40 while working the switch... that or just swap switches over with the passenger side.
Vehicle: 1985 Sierra Hardtop
Post Posted: Tue Oct 23, 2012 11:27 am
could you fit one yourself?? shouldnt be too hard
one like this, i used to sell them for truck use and they are pretty cheap
HELLA part number 6021 Warning Buzzer – 12V
Description
Piercing continuous sound. Suitable for a variety of applications e.g. headlamp, oil, handbrake, indicator, temperature, door close/open, brake fluid, etc.
Voltage
12V DC
Current Draw
Less than 500mA
Sound Level
85dB
Vehicle: 89 SWB vit
Post Posted: Tue Oct 23, 2012 11:34 am
i'll give anything a shot!
worst case scenario is I can't do it and i'll have to get someone else to for me :)
Post Posted: Tue Oct 23, 2012 11:35 am
Sound Level
85dB[/i]
85dB is probably louder than what you'd want for a headlight reminder...
Post Posted: Tue Oct 23, 2012 1:09 pm
Sound Level
85dB[/i]
you'll soon remember to turn your lights off though hey!! :)
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Oct 27, 2012 7:44 pm
Is possible just to rerouted ur wiring, move the headlight wire to accessories power not constant?
Users browsing this forum: No registered users and 82 guests
