It is currently Thu Nov 05, 2026 5:14 pm
Vehicle: 1985 Sierra Hardtop
Post Posted: Tue Oct 23, 2012 10:54 am
hello,
wondering if anyone has any rear seat belts for a 1985 Sierra that they dont need?? mines missing all pieces, even the bolts!! just seeing if there's anything out there as the next step might be to get some made.
cheers
Chris
Vehicle: 1985 sj50v SWB
Post Posted: Tue Oct 23, 2012 9:50 pm
I used 30 wide by 6 mm thick steel and welded two pieces on end to make aan angle bracket with 30 to 40 mm one side and 75 to 100mm other side or something which suited.
Went to the wreckers and got 83 jackaroo belt/mechanism (front ones i think) Anyway they bolt to the angle which bolts to the floor using the 2 holes in the floor. Also had to shape the buckle bit a little so they work in the stock clip which is attached to the back bench seat.
I'm sure there are many ways but this worked for me but most especially my mechanic!
As long as they work he said.
Vehicle: LJ20 LJ50
Post Posted: Wed Oct 24, 2012 5:19 am
lh rear http://seatsafe.com.au/store/index.php? ... ductId=292
rh rear http://seatsafe.com.au/store/index.php? ... ductId=291
$71.00 each
or just go to repco/convernty/bursons and ask for rear selt bets for a sierra. They are multi fit and would be around $55-85 depending on how you talk to them.
Camels have nice toes
Post Posted: Wed Oct 24, 2012 9:12 am
cheers guys, i had looked at Covs before but dont remember them having a listing them a Sierra, will have another look as we have an account with them
thanks again
Post Posted: Wed Oct 24, 2012 11:42 am
Nice... I wish I knew about those but I had limited time as I was about to fail the safety check .
I think I'll replace them for some of the ones linked above....
Cheers TZAR !
Users browsing this forum: No registered users and 19 guests
