It is currently Sat Nov 14, 2026 3:30 pm
Post Posted: Fri Oct 26, 2012 2:09 pm
Hi all what is needed or what do I have to do to install a disk brake conversion in the front of my 81 modle sj40t ute what are the components involved and how do U do it ECT sorry still new to this sort of stuff
Cheers Shaun
Post Posted: Fri Oct 26, 2012 2:17 pm
Buy a pair of complete front hubs from a 1.3L sierra, everything that goes on the end of the diff housing except for axle/c.v.
Post Posted: Fri Oct 26, 2012 2:33 pm
you may also need a master cylinder from a later model 1 litre (or 1.3 if you want to add a booster). the drum front run a different master cylinder to disk front, and the proportioning may be different. but I can't say for certain, it may infact work ok for you.
you may get away with just removing the residual pressure valve from the front lines (assuming it has one fitted being drum brakes)
I see your in D'bay too, if yuo want to pop around to have a look at my zook to compare the differences shoot me a PM.
Mark.
Post Posted: Sat Oct 27, 2012 12:50 am
And if the donor vehicle is a NT 1.3, then the Axles/CVs will also swap over for a strength upgrade.
Post Posted: Sat Oct 27, 2012 8:31 am
Ok thanks guys
Post Posted: Sat Oct 27, 2012 3:26 pm
I didn't change the master cylinder when I did mine, until I upgraded to booster. All worked fine, and mine is an early sierra.
Vehicle: SJ40T
Post Posted: Tue May 02, 2023 10:09 pm
I've located a disk front end to do this, but need a new master cylinder as mine is worn out. There are dozens of master cylinders for sale online, but I can't work out which one to order as none of them specify for the disk brake version. Does anyone have a link to the right one to buy?
Users browsing this forum: Google [Bot] and 64 guests
