It is currently Sun Aug 02, 2026 9:20 am
Post Posted: Mon Oct 29, 2012 11:37 pm
Hi, just got my jimny back on the road. Spark plug blew off the head smashing the coil pack. Had to get a helicoil to put it back in. Also had to change my tailshaft as the rattling was annoying the hell out of me. Tailshaft was modified as they eliminated the cv from the gearbox and replaced it with a uni joint. Anyway car is driving sweet only thing is I was getting 400 to 420 out of a full tank now I'm only getting 350 to 360. All new plugs a new coil pack. Any thoughts? Tried searching but I'm on an iPhone so it's pretty hard.
Ps car is completely standard.
Post Posted: Mon Oct 29, 2012 11:50 pm
o2 sensor is my suggestion.
what year is the jimny as there are 2 types of engine G13bb & the M13a?
Post Posted: Mon Oct 29, 2012 11:56 pm
99' G13bb
How many k's has it got now?
Post Posted: Tue Oct 30, 2012 7:25 am
Yeah 99 g13b. It's got 178000k's. is there any tuning involved when replacing the O2 sensor?
Vehicle: 2002 Suzuki XL7
Post Posted: Tue Oct 30, 2012 9:25 am
all ya do when replace O2 sensor is disconnect the battery when doing it so when reconnect with new o2 sensor the ECU adjusts to the new sensor.
In theory o2 sensors last around 100,000k but replaced mine at 150,000k, i ordered mine from the USA as sooooo much cheaper than here!
Post Posted: Tue Oct 30, 2012 9:57 am
Thanks guys. Appreciate the help :)
Post Posted: Tue Oct 30, 2012 2:33 pm
I just called my local Suzi dealer and nearly had a heart attack! $470.00 for an o2 sensor 8O 8O what website should I use and how much should i expect to pay?
Post Posted: Tue Oct 30, 2012 3:20 pm
Yeah around $120 off eBay from the guy that most of the guys buy parts off on this site. Repco wants around $120 at trade price so Could you please point us in the right direction to get an O2 sensor as that is a bit steep in price still.
Thanks.
Post Posted: Wed Oct 31, 2012 10:12 am
is there are thread any where that tells you how to install em?
Post Posted: Wed Oct 31, 2012 10:13 am
Post Posted: Wed Oct 31, 2012 10:49 am
disconnect battery
22mm spanner
unplug & remove old sensor
refit new sensor with a light smear of never-seize type stuff on the thread
plug back in
connect battery
take it for 2 drives
Post Posted: Sun Dec 02, 2012 10:31 pm
Done the O2 sensor and have noticed no difference in fuel consumption. Still getting about 360k /tank.
Post Posted: Mon Dec 03, 2012 9:46 am
360ks per how many actual liters?
Post Posted: Mon Dec 03, 2012 11:21 am
ah sory about late reply got mine from Summit racing like most exhaust and some other parts...
PS takes around 300Km - 500km for the ECU to remap itself so if if fuel consumption is bad after try cleaning the MAF sensor there is special cleaner that can clean them.
If really want to treat your motor get some Bitron to go in oil and some injector cleaner, my car went from 440 per tank to 520 now its been a few months since putting it in and gone back down to 420k per tank with the fuel injecor cleaner you get a good size bottle that lasts a while as only need to put a few ml in per tank. The only thing is the price of the Bitron bight out way the savings in fuel.
Post Posted: Mon Dec 03, 2012 11:28 am
Where you getting this info from?
Post Posted: Mon Dec 03, 2012 11:44 am
+1
Post Posted: Mon Dec 03, 2012 11:50 am
I learnt that from when i converted my car to E85 took just over 300k to adjust to the longer injector pulse width etc, also remember when i had a Jimny fuel usage was shocking after a big service for the first tank of fuel, then was ok after, I only got 320k out of tank usually got around 440 out of tank. The thing the ECU learns quickly is the MAP for idle.
When i change fuels now it only takes a few K to realise the fuel has changed, its harder for the ECU to go back to standard fuel than it does to E85.
Changing my O2 sensors took me around 400k before i noticed a difference, it idled a little higher and had a bit of a flat spot, it slowly smoothed out. Also probably depends on how bad the previous O2 sensors where.
Rhinopower might now about the Jimny ECU and how quick they are at learning.
Post Posted: Fri Dec 07, 2012 10:51 am
yeah im agreeing with Gecko too. AFAIK the Jim's have a learning ecu and changes map gradually over the course of a few tanks of fuel.
My hyundai was the same when I had that. an old trick was to disconnect the battery for 10mins. then drive it like you stole it for a day or so, as the biggest adjustments are done in the first few kms of driving, then they sort of even out after a while. You'd do the exact opposite if you want it to be fuel efficient, drive it like a girl for a day or so
whether the jim is the same or not i dont know. but i suspect it is.
MY BUILD THREAD HERE!!!!!
Post Posted: Mon Dec 10, 2012 10:02 pm
very interested to know how much difference new o2 makes
Post Posted: Thu Dec 13, 2012 1:31 pm
well ive probably done about 800k's with the new O2 sensor, and It has done bugger all.. :(
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Dec 13, 2012 5:27 pm
Has it got an engine light on?
Post Posted: Fri Dec 14, 2012 11:05 am
na no engine light.
Users browsing this forum: No registered users and 19 guests
