| Author |
Message |
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Sun Jan 22, 2012 9:44 pm |
Just a quick question. does a hilux cv fit inside a sierra knuckle?
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Sun Jan 22, 2012 10:04 pm |
Brett wrote: Just a quick question. does a hilux cv fit inside a sierra knuckle?
No..
In fact a hilux CV only JUST fits in a hilux knuckle. They have flats machined into the bell to enable install and removal.
Brett
 Posted: Sun Jan 22, 2012 10:35 pm |
Well that killed the idea i had then. thanks any way
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Sun Jan 22, 2012 11:42 pm |
want33s wrote: Brett wrote: Just a quick question. does a hilux cv fit inside a sierra knuckle? No.. In fact a hilux CV only JUST fits in a hilux knuckle. They have flats machined into the bell to enable install and removal.
x2 they dwarf Sierra cv's. Even chromos are a tight fit.
tanshi
 Posted: Tue Oct 30, 2012 10:35 am |
any one know what a GU patrol cv is like in comparison to hilux?
also any could some one measure the diameter of the lux front axle tube on the outer end...
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Tue Oct 30, 2012 10:41 am |
tanshi wrote: any one know what a GU patrol cv is like in comparison to hilux?
also any could some one measure the diameter of the lux front axle tube on the outer end... It's hugerer.
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5936 Location: Northcliffe, W.A.
 Posted: Tue Oct 30, 2012 11:10 am |
joeblow wrote: tanshi wrote: any one know what a GU patrol cv is like in comparison to hilux?
also any could some one measure the diameter of the lux front axle tube on the outer end... It's hugerer. x2 They're massive.
tanshi
 Posted: Tue Oct 30, 2012 11:16 am |
how massive? measurment?
the specs i have say they are 90mm diameter on the bell
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Tue Oct 30, 2012 11:55 am |
Lux axle tube OD from memory 80mm
tanshi
 Posted: Tue Oct 30, 2012 1:07 pm |
GQ is 93mm diameter GU is around 10mm bigger
Some one got a chromo Sierra CV around they can measure a diameter for me?
zooky08
Joined: Fri Nov 27, 2009 10:30 pm Posts: 3426 Location: imbil/gympie. qld
 Posted: Tue Oct 30, 2012 2:50 pm |
tanshi wrote: GQ is 93mm diameter GU is around 10mm bigger
Some one got a chromo Sierra CV around they can measure a diameter for me? Edit: 82mm
_________________ 03 Jimny 30 km2s 75mm lift f&r locked winch
sideways
 Posted: Wed Oct 31, 2012 2:06 am |
SierraDan
 Posted: Wed Oct 31, 2012 2:12 am |
Get the micrometer out
_________________ mlm
sideways
 Posted: Wed Oct 31, 2012 2:29 am |
SierraDan wrote: Get the micrometer out  I wish I had a 75-100mm micrometer so I could make a smartarse comment here.
zooky08
 Posted: Wed Oct 31, 2012 4:48 am |
i used a tape measure
SierraDan
 Posted: Wed Oct 31, 2012 5:13 am |
sideways wrote: SierraDan wrote: Get the micrometer out  I wish I had a 75-100mm micrometer so I could make a smartarse comment here.  Ive got one. No chromos but
Teracis
Joined: Sat Dec 11, 2010 10:03 pm Posts: 2261 Location: Gold Coast
Vehicle: Daisy
 Posted: Wed Oct 31, 2012 6:23 am |
What the hell are you buggers doing measuring chromos at 2am...
SierraDan
 Posted: Thu Nov 22, 2012 1:54 pm |
sideways wrote: I got 83.6mm. I got 83.7mm (pretty crap tolerances  ) Lux chromo i got 93.6mm
