It is currently Wed Jul 29, 2026 1:44 pm
Vehicle: 30s front locker barwork
Post Posted: Fri Jun 05, 2009 11:30 pm
i m goin to buy new led lights for my rear bar and i want to no can i wire them striaght up to the old light cables and do i need anything else to make it work right
thanks sean
Post Posted: Sat Jun 06, 2009 12:27 am
Led's wire up the same as the old lights.. You may have to replace your indicator flasher can with an LED flasher unit to stop them flashing ridiculously fast.
Post Posted: Sat Jun 06, 2009 5:43 am
or put in a resistor like i did
lesspostingmorewheeling
Post Posted: Sat Jun 06, 2009 7:01 am
be careful with the wiring read the instruction the wire colours aren't what you would expect them to be (red isn't positive black isn't negetive etc.)
Post Posted: Sat Jun 06, 2009 1:11 pm
Most of the LEDs I've wired up used RED as BRAKE.... YELLOW as indicator... WHITE as TAILLIGHT and BLACK as EARTH but this may not be the case with all of them.
Post Posted: Sat Jun 06, 2009 1:20 pm
A lot of em are same as trailer wiring
red is brake
brown is tail
yellow or green is indicator
white is earth
black is reverse
youll also need a flasher unit that doesnt speed up with less load, Tridon make a road train one that fits the plug but I am over telling people about it cause nobody has ever been succesful in buying one and plugging it in without setting fire to something :)
Post Posted: Sat Jun 06, 2009 1:54 pm
red is brake
brown is tail
white is earth
black is reverse
How the hell do you set fire to something plugging in a flasher can??? :?
Post Posted: Sat Jun 06, 2009 2:18 pm
These are available at most auto parts shops. I fitted one to my car which is ALL LEDs and it plugged straight in and works fine.
Post Posted: Sat Jun 06, 2009 4:24 pm
red is brake
brown is tail
white is earth
black is reverse
I dont know, the flasher is 2 pin, the socket is 3, so it can go in a right way and a wrong way, didnt matter how many times you tell people to find the power pin 1st they jsut shrug and figure they will jsut plug it in and see
Post Posted: Sat Jun 06, 2009 11:29 pm
thanks for the help i will post some pics n that when i am done
Post Posted: Mon Dec 27, 2010 3:53 am
So where does it go?
Post Posted: Mon Dec 27, 2010 4:01 am
Where does what go? :?
Post Posted: Mon Dec 27, 2010 5:23 am
Flasher can is located at the top of the fuse box... Near the accellerator pedal.
Post Posted: Mon Dec 27, 2010 5:50 am
i only have leads on the rear and my flasher tickers really fast.
would getting a led flasher box fix this. or are they only for cars that have leds all round.
Post Posted: Mon Dec 27, 2010 5:55 am
red is brake
brown is tail
white is earth
black is reverse
that would be the case for all the ones ive done so far
Post Posted: Wed Dec 29, 2010 11:54 pm
You can mix and match incandescent with the LED's, the electronic flashers blink at the same speed no matter what is connected.
I tired to use the resistors with the stock flasher and it was just a mess. The wires broke off one of the resistors so i had to buy another. Then the resistors got so hot they melted the electrical tape.
The resistors also defeat the purpose of having LED's because the resistors draw just as much amperage as the old lights.
I found an electronic flasher and all my lights have worked great since. I can also leave my LED park lights on for over 14 hours and it doesn't drain my battery. The only downfall is that the flash will not speed up when a light is out or disconnected.
LED's totally rock. armsup
Post Posted: Fri Oct 05, 2012 10:14 am
Can anyone tell me which of these is a suitable flasher to suit some 12v led indicators?
http://www.supercheapauto.com.au/online ... escription
or
This kind of stuff really isn't my thing
Post Posted: Fri Oct 05, 2012 10:21 am
Neither of those will work properly, you need a non load sensing flasher unit, the LED's place less load on the electrical system, which is why they flash faster.
Post Posted: Fri Oct 05, 2012 10:54 am
Do you have a part number for one that would work?
Post Posted: Fri Oct 05, 2012 11:29 am
Mine has this on it: Bosch
P122
Electronic
Flasher
010410
Post Posted: Fri Oct 05, 2012 12:19 pm
Have at look at aftermarket motorbike units, they change to LED all the time.
Post Posted: Fri Oct 05, 2012 3:11 pm
Thanks for the info, I will follow up the Bosch unit.
Users browsing this forum: Google [Bot] and 464 guests
