It is currently Tue Jun 16, 2026 2:30 am
Post new topic Reply to topic  [ 97 posts ]  Go to page 1, 2, 3, 4  Next
Vehicle: 1994 sierra
Post Posted: Fri Nov 02, 2012 7:44 pm
hey just got a1994 sierra ,which is better vitara 1.6 carby or efi
needs a little more power ?
Vehicle: LWB Sierra & XL7
Post Posted: Fri Nov 02, 2012 7:47 pm
efi...
that is all.
'92 Vitara & Camper trailer
Post Posted: Fri Nov 02, 2012 7:55 pm
EFI 1.6 is 484874874784743764376067608659785487400 better than carb 1.6.
Vehicle: 4wd
Post Posted: Fri Nov 02, 2012 8:02 pm
EFI...
Watch out or you'll get sued.
Vehicle: Sold zuk got a Bt50
Post Posted: Fri Nov 02, 2012 8:36 pm
I'll join in as well EFI
bt50 now but still love the zooks
Post Posted: Fri Nov 02, 2012 8:42 pm
what they said, but preferably without the cracked blocks that seems to be plaguing the G16b's.
Post Posted: Fri Nov 02, 2012 8:58 pm
G16A carbies crack blocks too.
Vehicle: SJ80, SE416
Post Posted: Fri Nov 02, 2012 8:59 pm
Happens to G16a as well - I have owned 3 cracked G16a engines as well as the G16b in my Vit!
The G16a in my white coily was cracked at the front and the rear of the block!
Vehicle: 1989 Vitara
Post Posted: Fri Nov 02, 2012 9:15 pm
I know I should use the search function but its pain on the butt on this mobile. Can someone give quick answer as to why they keep cracking?
Post Posted: Fri Nov 02, 2012 9:23 pm
so it's official G16 suck the big one... jam a J20a or a H25a in there & be done with it.
Post Posted: Fri Nov 02, 2012 10:03 pm
G13b or G13bb FTW!
Post Posted: Fri Nov 02, 2012 10:17 pm
G's have been cracking for years
EFI G16b.
If your fitting a J, You may as well go H27 :D
Post Posted: Fri Nov 02, 2012 11:10 pm
Funny thing is every G16 I've owned thus far has had at least 1 very small crack on the drivers side of the block!
There aren't too many cracked G13 engines around to my knowledge...
Post Posted: Fri Nov 02, 2012 11:23 pm
Youve been lucky!
Ive never had a cracked one, But have only ever had baleno. Ive cooked one and she still went like a cat on fire with oil bubbling and black smoke. Only thing that stopped me was the crank sensor melted casing, arcing out onto the sump. Block didnt crack. :lol:
I then changed the whole engine..
Vehicle: 4wd
Post Posted: Sat Nov 03, 2012 6:06 am
So it's safe to say the g16's are a cracking motor!
Post Posted: Sat Nov 03, 2012 8:11 am
Boom tsssh
They crack because they were made with alloy that isn't the greatest quality, with years of expansion and contraction even the best alloys will crack.
Post Posted: Sat Nov 03, 2012 9:28 am
So I should shoe horn a J20+AW4 into my Jim then aye... ;)
Post Posted: Sat Nov 03, 2012 10:10 am
nah just get a baleno block :D
Vehicle: Daisy
Post Posted: Sat Nov 03, 2012 10:56 am
Got the baleno motor, it's the putting it in that is going to be the long part...
Post Posted: Sat Nov 03, 2012 11:05 am
How many km are Bal engines good for? 200-300k like Vits?
Post Posted: Sat Nov 03, 2012 11:28 am
They should be no different.
Post Posted: Sat Nov 03, 2012 11:57 am
I figure in a Bal they're much less stressed than in a Vit.
Post Posted: Sat Nov 03, 2012 12:02 pm
I know the block castings are different
Different mounts as vit for ps pump
Different front casting section for crank sensor
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Tue Nov 06, 2012 9:27 pm
Has anyone slipped a J20A into a sierra??
I have seen many conversion kits for 1.6 but not for a 2.0
Post Posted: Tue Nov 06, 2012 10:38 pm
Yeah its been done plenty of times.
Conversion kit.... http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=18&category_id=66&option=com_virtuemart&Itemid=53
Tanshi got his running with the J20, before tearing it down.
I'm half way through the same conversion.
IMO its more work, but if you are happy to address the strength issues with the rest of the drive line the J20 is a stella choice for a sierra ( atleast on paper ). Worth mentioning that the fit quite well into the engine bay.
Post Posted: Wed Nov 07, 2012 5:16 am
Strength issues ? Gearbox and diffs ?
Post Posted: Wed Nov 07, 2012 8:41 am
i have one in my LJ now :)
Post Posted: Wed Nov 07, 2012 1:35 pm
yep.
Other suspect parts would be the transfer case ( long term) and deifnately uni-joints. Upgrading to hilux based drive shafts would be a good idea.
There is no reason why you couldn't just drop the motor in and address these other things as they become an issue, but just be aware that a J20 FAR exceeds the power and tourque handling abilities of most of the sierra drive train.
And a brake upgrade is a must!
Post Posted: Wed Nov 07, 2012 4:46 pm
Then 1.6 efi is probably enough !
Post Posted: Wed Nov 07, 2012 4:51 pm
the 1.3 carby is enough. but the best?
Users browsing this forum: No registered users and 115 guests
