1 good con blue bonnet $100 2 good con blue doors $75 each 1 good con white hardtop rear door (full door) - $75 front section of removable fibreglass hard top - $40 white front grill $30 front and rear w/t springs, i think 2" lift but best you come measure $50 each
fr / Rr diffs + gbox + transfer case - im pretty sure these are all good. it looks like its been bogged in the beach and taken a bit of water, fluids have been drained, new oil + clean out and they should be all good. $80 each ill give a 7 day warranty on these as well.
set of 5 standard wheels, 2 with good desert dueler h/ts other 3 are reasonable $100
1.3 litre motor - motor is u/s but has good carby / dizzy / ect. no starter or alt. make an offer on engine or bits
front and rear bumpers good condition. front bumper has a good heavy duty spotlight bar on it $50 each
also have a set of unfinished custom rock sliders. 1 side is pretty much complete, heavy guage tubing, looks like they weld to the chassis? but could be made to bolt up. other side needs welding finished. $50
if anyone wants a good condition w/t chassis as well make us an offer.
located in malaga, perth. i want this stuff gone asap, it will all be going to scrap in a couple of weeks if no 1 takes it so get in quick.
CALL OR TXT 0407732337 and ill txt back, if you want stuff dont reply here as i dont check regularly. cheers, lee
Users browsing this forum: No registered users and 18 guests
