It is currently Fri Nov 13, 2026 12:42 pm
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Mon Nov 05, 2012 6:57 pm
Hey guys. The first time ive checked my sierra into 4H today and locked the front hubs in. But when i make a turn the wheels start locking up and gets tight/jammed. Now i know what lockers are etc and how diffs work but im unfamiliar with 4wd mode as ive never used it.
Any help or ideas/ is this normal when in 4wd mode?
cheers in advance!
Vehicle: 91 sierra, g16b,lift,30's
Post Posted: Mon Nov 05, 2012 6:59 pm
Are you fully engaging the hubs?
on tar?
Post Posted: Mon Nov 05, 2012 7:01 pm
yes the hubs are fully engaging and yes on tar
Post Posted: Mon Nov 05, 2012 7:06 pm
not a good idea using 4wd on high traction surfaces
Post Posted: Mon Nov 05, 2012 7:08 pm
ok. so i stuffed up lol. wont happen again
Post Posted: Mon Nov 05, 2012 7:09 pm
ON tar ouch!!! What you are experiencing is wind-up. Not good for any of the drive train! 4x4 is only to be used on low traction surfaces where the tires will slip, not tar!
Post Posted: Mon Nov 05, 2012 7:13 pm
geez lucky i didnt break anything.
Its just that i have a slight growling noise coming from underneath backing off and on accelerator and thought it might be the rear diff. So i disconnected the rear tail shaft and drove it home on the front diff in 4wd mode. But massive vibration when i done that. so pulled over and slipped the rear shaft back on. No vibration in 4wd.
really lucky i didnt stuff anything
Post Posted: Mon Nov 05, 2012 8:42 pm
You shouldn't have any vibrations running with the rear shaft out and in 4H. It sounds like you have other problems as well
Post Posted: Mon Nov 05, 2012 8:48 pm
yeah it was weird. didnt think it should make a difference if i have the rear shaft in or out in 4wd.
Post Posted: Mon Nov 05, 2012 9:11 pm
jack shaft uni's
Post Posted: Mon Nov 05, 2012 9:17 pm
but the jack shaft is always spinning whether the front or rear shaft is in
Post Posted: Mon Nov 05, 2012 10:53 pm
Front shaft unis. Probs haven't been used for a while and are stiff/semi seized
Post Posted: Mon Nov 05, 2012 10:54 pm
Did you disengage the hubs when you put the rear shaft back in?
Post Posted: Tue Nov 06, 2012 5:14 am
At first I left them engaged. And drove it in 4wd with no vibration
Users browsing this forum: No registered users and 49 guests
