It is currently Sun Oct 25, 2026 12:21 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2  Next
Post Posted: Tue Nov 06, 2012 9:58 pm
I know they are a WIDE motor but...
Has it been done?
Is it possible?
Post Posted: Tue Nov 06, 2012 10:20 pm
i reckon it would be nearly unpossible....
can i ask why?
Post Posted: Tue Nov 06, 2012 10:46 pm
Free 2L impreza motor and gearbox + my other swb i'm building needs a new engine.
Post Posted: Tue Nov 06, 2012 10:48 pm
Anything is possible if you have the budget and skills.
But it would just be the start of the mods. Not a single remaining part of the driveline would withstand that sort of power and torque.
EDIT: NA EJ20 is only 100kw. Should be ok if you drive nice.
Post Posted: Tue Nov 06, 2012 10:49 pm
sell the boxer & put the money towards a G16
Post Posted: Tue Nov 06, 2012 11:11 pm
^^ dont listen to them... do it!!! =)
Vehicle: '96 LWB trayback
Post Posted: Tue Nov 06, 2012 11:52 pm
Boxer engine would have to be wider than the clearance between chassis rails? Measure it up, I'd be amazed if it would fit but would love to see the potential.
Post Posted: Wed Nov 07, 2012 2:31 am
The tyres would rub on the heads on full lock. :lol:
Post Posted: Wed Nov 07, 2012 5:16 am
Won't fit. The engine and gearbox would sit too high to work in the tunnel. You'd have to somehow mate another gearbox to it as well
Vehicle: Yellow Ute
Post Posted: Wed Nov 07, 2012 5:56 am
Moar body lift pompoms
Vehicle: 98 coily..Max.
Post Posted: Wed Nov 07, 2012 6:08 am
Mid engined...
Vehicle: WR250F/Jeep XJ
Post Posted: Wed Nov 07, 2012 6:28 am
I think Gwagen has done the measurements and confirmed it to be impossible to fit into the engine bay for what would be a suitable conversion. Just put a commodore motor in you know you want to ;) .
Post Posted: Wed Nov 07, 2012 8:00 am
I'd rather out in a 1L than a commodore motor!!!!
Time to get a g16b. My mate has an auto lwb bit for sale at the right price, will the auto fit in a swb sierra??
Post Posted: Wed Nov 07, 2012 9:00 am
use the drive train from the subaru & make it AWD
Post Posted: Wed Nov 07, 2012 9:03 am
:rofl: :rofl: :rofl: :rofl:
It's gonna need a pretty big ruf and chassis extension to make that work
Post Posted: Wed Nov 07, 2012 9:41 am
An EA81 or EA81T motor should fit been much narrower pushrod etc.
I fell in love with the older pushrod subey engines due to their indestructibility and power when supercharged.
A speedway one blew away Fontana and top racers years ago on methanol and a hillclimber did the same to much more sophisticated bike engined setups on a few QLD hillclimb events.
http://www.debower.net/gimages/pa20.JPG
It fits well in a Suzuki Hatch FWD and RWD toyota W series box adapter are available for RWD only or for Toyota running gear 4wd.
Vehicle: 1.3 Tin Top
Post Posted: Wed Nov 07, 2012 11:35 am
Dont conform and put a g16 in. Do the boxer and make it the meanest sounding sierra on the planet
Post Posted: Wed Nov 07, 2012 11:46 am
flat 4's sound like a soggy harley. :roll:
quad rotor is where it's at, sounds like a F1 engine & shoots flaming bees & hornets out the exhaust . 8)
Vehicle: 99 Grand Vitara
Post Posted: Wed Nov 07, 2012 12:29 pm
Pretty sure the flames are from something like a bee*r rev limiter
http://www.strictly4x4.com.au
Post Posted: Wed Nov 07, 2012 12:40 pm
considering it's running an aftermarket ecu, i doubt they'd tack on a bee-r limiter, but yeah it would be an ignition cut rev limiter. the big fire balls is just unburnt fuel getting ignited in the exhaust from when he lifts off.
Post Posted: Wed Nov 07, 2012 1:54 pm
why not go all out and chuck a 6 rotor in it in that case. good luck with engine longevity
Post Posted: Wed Nov 07, 2012 3:26 pm
a rotor if looked after like anything mechanical will last, 2 mates have rotors that were built in the early 90's & neither of them have had any of these so called "longevity" issues, one is a 12a extend port & turbo & the other is a 13b bridge port.
Post Posted: Wed Nov 07, 2012 3:35 pm
my point was. a rotary in a 4wd is kinda pointless. just like a diesel in a sierra
Post Posted: Wed Nov 07, 2012 3:36 pm
why's that, cause they have no torque?
Post Posted: Wed Nov 07, 2012 3:55 pm
the link is broken to the dyno sheet i posted but this was in the youtube thread
gregdixon wrote:
gregdixon wrote:
gregdixon wrote:
Polar_Bear wrote:
Rotaries have :no: torque
i call BS, on that one... they have a very flat torque curve.
700+ lb of torque from essentially a 1.3l
http://www.madazmotorsport.bravehost.co ... 2-2008.jpg
A 13b is the equivalent to a 2.6l piston engine due to the greater displacement per revolution. If I read this right
http://www.drivingsports.com/site/2008/ ... uivalency/
If I use the HP calculation of torque x rpm / 5252, working back from that Dyno sheet that car is producing max HP at around 1800 rpm. If that is correct that its heaps of torque and I will eat my own words.
Post Posted: Wed Nov 07, 2012 4:29 pm
ha i researched the shit out of this a while ago, might have even posted some links in the rotor in a sierra thread... they have more pull across a larger rev range and I think even starting lower? maybe? than a g16.
Post Posted: Wed Nov 07, 2012 4:33 pm
i agree shakes, that was my attempt at sarcasm, really should have used the sarcastic font
Post Posted: Wed Nov 07, 2012 4:38 pm
The dont they idle at 2g?
I think you will find that any rotary making good power AND torque from down low will be lumpier than a stroker and there for pointless in a 4wd.
Bye
Post Posted: Wed Nov 07, 2012 4:43 pm
Bye
yeah maybe when peripheral ported :roll:
stock 13b it will idle around 1000rpm
Vehicle: 1985 lwb sierra UTE
Post Posted: Wed Nov 07, 2012 5:15 pm
subi engines are a very awsome motor as fatzook said it would be a massive job but it would be fricken awsome if u could pull it off
Users browsing this forum: No registered users and 135 guests
