It is currently Tue Oct 27, 2026 11:32 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
Post Posted: Wed Nov 07, 2012 5:59 pm
These may give you some ideas, pity there is no recent updates :(
http://www.pirate4x4.com/forum/suzuki/6 ... stuff.html
Post Posted: Wed Nov 07, 2012 6:09 pm
not much sierra left in that one :lol:
Post Posted: Wed Nov 07, 2012 6:27 pm
Trypt wrote:
The dont they idle at 2g?
I think you will find that any rotary making good power AND torque from down low will be lumpier than a stroker and there for pointless in a 4wd.
Bye
yeah maybe when peripheral ported :roll:
stock 13b it will idle around 1000rpm
with a skilled tuner it doesnt matter how aggressive the porting is, a 12a or 13b can idle smoothly at 800-900rpm one of my tradeschool lecturers lives and breathes rotors and has for 30+ years and has done it to many rotors including IDE carbed rotors. but apparently its quite the trick to get it right but is doable
Post Posted: Wed Nov 07, 2012 7:52 pm
Not a cool rotary unless its going "braap braap braap braap" and skipping sideways at idle.
Post Posted: Wed Nov 07, 2012 8:18 pm
he still gets the typical noise under throttle, and loves the stealth aspect of it
Post Posted: Wed Nov 07, 2012 8:21 pm
Thats nice.
Post Posted: Wed Nov 07, 2012 10:03 pm
ea81 will fit
Post Posted: Wed Nov 07, 2012 10:35 pm
so does a VN commodore motor.... still doesn't make it a good choice. :wink:
Post Posted: Thu Nov 08, 2012 6:36 am
An ET pulsar motor (1.5L turbo) fits too but the starter hangs too low and the diff hits the starter motor on compression...
Post Posted: Thu Nov 08, 2012 11:01 am
The reason I say ea81 is thats its pushrod has heaps of usable torque and weighs a tad less than a G16b unlike the SOHC and DOHC units which weigh almost double a G13A. For some reason the SOHC. DOHC units are super heavy compared to the OHV which is also used for ultralights and renown for its durabilty, no belts to change or chains to weigh it down and simple pushrods to keep it all at intended rpm and service ability.
Specifications
Displacement: 1,781 cc
Bore: 92 mm
Stroke: 67 mm
Compression Ratio: 8.7:1
Valvetrain: OHV Pushrod
Horsepower: 73 bhp (54 kW; 74 PS) at 4,800 rpm
Torque: 94 lb·ft (127 N·m) at 2,400 rpm
Found on
1980-1989 Subaru Leone
1981-1987 Subaru BRAT
g13a
53 kW (71 hp) @ 6,000; 102Nm (75 ft-lb) @ 4,000)
g16b
95 hp (71 kW) @ 5,600 rpm; 132nm (98 ft-lb) @ 4,000 rpm.
versus
(54 kW; 74 PS) @ 4,800 rpm; 127nm (94 lb·ft) @ 2,400 rpm!!!!!!
Post Posted: Thu Nov 08, 2012 11:09 am
looks like a shit load of effort for little to no gain.
Post Posted: Fri Nov 09, 2012 1:50 pm
It would be different but still:
Realiability is superior,
ea81t turbo bits bolts on,
ea series is bullet proof
sits lower in engine bay
better torque (boost or not)
no timing belts or chains
stock internals stronger
sounds better :mrgreen:
My pick would be a 1mm+ bore factory g13b GTI bottom end
ported g16a top end with bigger exhaust valves, supercharger,
SU, good pipes & adapted vitara box with matching Vit bits.
Post Posted: Fri Nov 09, 2012 3:20 pm
then you'd have to lower your drive train to suit... personally i think it's a stupid idea which ever way you try to polish that turd, just because it's a free engine doesn't make it a good idea.
Vehicle: 94 LWB VITARA
Post Posted: Sat Nov 10, 2012 8:20 am
rotor sound done right=schweeeet!!! subaaaroo noise done in anyway is like what atari said but more like a wet fart just before someone proper shits emself!
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Nov 10, 2012 3:05 pm
Attari4x4 it only sits lower due to the enginebeing a boxter engine there not that tall until the later 1s,they used to keep the spare tyre on top of it under the bonnet ((im not taking the piss :))
Post Posted: Sat Nov 10, 2012 8:42 pm
You wouldn't get the crankshaft any lower, there's still a diff in the way. Actually, just looking at that pic... The camshaft appears to be below the cank so it'l probably have to go higher to get diff clearance.
Post Posted: Sat Nov 10, 2012 10:19 pm
Finally! A use for SPOA :lol:
Post Posted: Sun Nov 11, 2012 4:58 pm
:rofl:
Post Posted: Sun Nov 11, 2012 8:10 pm
do it subies all the way
Users browsing this forum: No registered users and 911 guests
