| Author |
Message |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13011 Location: Melbourne
 Posted: Mon Nov 12, 2012 12:12 pm |
If it has 99psi compression now it had 99 psi compression when it was parked, so that's not the problem.
tonyevans
Joined: Sun Jan 16, 2011 11:18 pm Posts: 1998 Location: Lightning Ridge NSW
 Posted: Mon Nov 12, 2012 12:16 pm |
You don't think less than half the compression would make starting a little difficult?????????
Gwagensteve
 Posted: Mon Nov 12, 2012 2:14 pm |
Did it make starting difficult before the battery went flat?
Best check the tyre pressure too- it's going to be as relevant as compression. sorry, I'm not being a shit, but you're wasting your time checking the mechanical condition of the motor. It won't have changed since the battery went flat.
I might have missed this - have you swapped in a known good battery? I know you have charged the battery numerous times and it will crank the car, but I had a battery die in my STi and it would crank and start and run the car no problem. It didn't start once and needed a jump, and then about three weeks later, whilst driving down the road, the car just stopped - dead battery. It charged and jumped as per normal, but wouldn't run the car.
If the battery went as flat as it sounds, it's unlikely to recover properly, even though it might crank the car over.
tonyevans
 Posted: Mon Nov 12, 2012 3:24 pm |
How about a brand new NZ70 - Oh no good it won't connect to the TINY battery clamps will it  or fit in the tiny hole  - I guess I will just pop down the shop and buy a new one - Oh the shop is 75ks away so I had better use the wheel barrow I do see what you are saying Steve but things are not that easy out here - I am going to try and track down another battery tomorrow from a mate but I have tested this one with a battery load tester but right now I will try anything.
atari4x4
 Posted: Mon Nov 12, 2012 3:30 pm |
tried jump starting it with another car attached to the battery
tonyevans
 Posted: Mon Nov 12, 2012 3:34 pm |
Tried that with the NZ70 Battery but I only have shitty jumpers I use for charging from the Solar system
JrZook
 Posted: Mon Nov 12, 2012 3:47 pm |
Why not try paralleling the NZ70 battery with the jumpers to the battery that's already in there? Will give that extra bit of kick if needed.
tonyevans
 Posted: Mon Nov 12, 2012 3:51 pm |
JrZook wrote: Why not try paralleling the NZ70 battery with the jumpers to the battery that's already in there? Will give that extra bit of kick if needed. See Above
stockman
Joined: Thu Nov 05, 2009 10:30 pm Posts: 5319 Location: Canberra
Vehicle: 4wd
 Posted: Mon Nov 12, 2012 3:56 pm |
stockman wrote: I had a similar issue recently. Different vehicle, but similar issue.
-My ride on mower. Battery was flat, charged it and it held 12v. Cranked, but no start. -Charged it again and boosted it off my car. Cranked, but no start. -Replaced battery. Cranked and started first go.
I asked my electrician friend why it didn't start when I boosted it with another battery. His reply was the battery was farked and was sucking the power from the booster battery, but not letting it pass through. Take out vit battery, put in good battery, hold terminals against battery poles and get your wife to crank?
_________________ Watch out or you'll get sued.
Red89
Joined: Tue Jan 12, 2010 10:30 pm Posts: 2801 Location: Perth
 Posted: Mon Nov 12, 2012 3:58 pm |
Pull old battery out and run jumper leads from new battery to the battery leads running to the motor. When I cut my car up we had the fuel tank and battery sitting on the bonnet and just connected the cables and hoses to where they should be. Decent leads would be better though.
tonyevans
 Posted: Mon Nov 12, 2012 4:04 pm |
stockman wrote: stockman wrote: I had a similar issue recently. Different vehicle, but similar issue.
I asked my electrician friend why it didn't start when I boosted it with another battery. His reply was the battery was farked and was sucking the power from the booster battery, but not letting it pass through. Take out vit battery, put in good battery, hold terminals against battery poles and get your wife to crank? See Above a couple more - You cant get an NS70 in the battery bay because it is too big. I am going to cook tea now as I am starting to get pissed off and it's NOT at you guys because I know you are trying to help me - it's the bloody Vitara - Tomorrow I will be calm Tomorrow I will be calm Tomorrow I will be calm Tomorrow I will be calm Maybe not
GeckoXL7
Joined: Tue Sep 25, 2012 8:12 pm Posts: 1173 Location: VIC
Vehicle: 2002 Suzuki XL7
 Posted: Mon Nov 12, 2012 4:39 pm |
Wow hold terminals to bat lol and start the car... Goodbye tony... Have u sen a spanner fall on a car bat before?
Do as red89 says as sometimes if trying to jump a dead bat that's gone faulty the dead bat will drain the power from good bat.
stockman
Vehicle: 4wd
 Posted: Mon Nov 12, 2012 4:54 pm |
GeckoXL7 wrote: Wow hold terminals to bat lol and start the car... Goodbye tony... Have u sen a spanner fall on a car bat before?
I know Tony is not stupid. I said hold terminals against battery poles not hold the poles.
GeckoXL7
 Posted: Mon Nov 12, 2012 5:37 pm |
I know lol. But there is people out there that are dumb enough thinking its only 12volt. Like putting a snatches strap on a tow ball.
I usually stay away from bat when jumping. Would clamp them
Think tony needs a mirical wake up and it just starts
royce
 Posted: Mon Nov 12, 2012 7:38 pm |
got me stuffed, check how many volts you have at the coil positive while the engine is cranking?
tonyevans
 Posted: Tue Nov 13, 2012 7:09 am |
Taking a day off from it today and going to talk to an old mate of mine Ned Kelly  No I have not lost it - He is a local property owner who used to run a bush wrecking yard here and is a bush mechanic of Looong standing. If he can't work it out I might just ask Shep for instructions  PS - He might even have a new battery that will fit
Mickc
Joined: Fri Jun 03, 2011 8:18 pm Posts: 107 Location: brisbane
 Posted: Tue Nov 13, 2012 3:56 pm |
Hi Tony, look like you know more about this Vit then the rest of us but just somthing the clever people on this forum might have overlooked. The car starts and run for a second before cutting out and wet plugs indicate it could flooded. In good old days cars used to have a start elect circuit and a run circuit, now its all in the ECU or is it? Somebody might be able to verify if this true and how you might be able to test it. PS. don't you wish it had a carby and points system?
JrZook
 Posted: Tue Nov 13, 2012 4:09 pm |
It could be possible that it is flooding/flooded. If so you could try removing the fuel pump fuse or relay and try cranking it over with a bit of throttle to see what happens
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Tue Nov 13, 2012 5:05 pm |
I think I have a FSM for one of them. I'll see if I do and I could post it to you to help you out.
_________________ Camels have nice toes
tonyevans
 Posted: Wed Nov 14, 2012 6:38 am |
tonyevans
 Posted: Wed Nov 14, 2012 6:41 am |
Mickc wrote: Hi Tony, look like you know more about this Vit then the rest of us but just somthing the clever people on this forum might have overlooked. The car starts and run for a second before cutting out and wet plugs indicate it could flooded. In good old days cars used to have a start elect circuit and a run circuit, now its all in the ECU or is it? Somebody might be able to verify if this true and how you might be able to test it. PS. don't you wish it had a carby and points system?  Hi Mick - Rest assured "I know nothing" about these new fangled things or at least did not until it would not start - Since then I have been on a crash course - Tony
tonyevans
 Posted: Wed Nov 14, 2012 7:30 am |
Just got hold of a BRAND NEW battery TWICE the size of the normal one in it - Jury rigged the leads - Result
Motor turned over like there was no tomorrow but did not start or fire at all.
christover1
 Posted: Wed Nov 14, 2012 7:44 am |
FSM = Factory Service Manual. The Haynes versions are less than helpful, I'm told.
Mine has an earth wire from back of head near dizzy, to the firewall. It could be there for the dizzy? Worth checking that.
christover1
 Posted: Wed Nov 14, 2012 7:46 am |
Something is stealing the power from the spark. May be a fault that also caused battery to drain on accessories.
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Wed Nov 14, 2012 8:10 am |
What aftermarket electrical things are added to the car? Stereo? UHF? Have you checked all the fuses in the back of units like this? The fuses may have went when they were trying to draw power but the voltage from the battery was not sufficient and depending how they are wired could be disrupting a circuit?
tonyevans
 Posted: Wed Nov 14, 2012 8:19 am |
christover1 - The manual I have is the Suzuki one on disk (PDF) but it is USA I don't know if there are different ones - I don't think so. The manual Trouble shooting only talks about NO spark not Weak spark and I really do think this is the problem. Just checked for that wire and it seem fine
ZookFan - It had a alarm system that I thought was the problem and have removed it entirely from the car - There is a stereo that replaces the original and that would be on standby with the key on Acc as well as the clock etc.
JrZook
 Posted: Wed Nov 14, 2012 9:57 am |
Well to check that weak spark see if you can just clobber something together to test how far it can jump without shocking yourself. The breakdown voltage for an air gap of 1cm between 2 electrodes is roughly 30kV. Stock stuff should be able to jump that. Also check the voltage at the coil. Should be very close to the battery voltage.
tonyevans
 Posted: Wed Nov 14, 2012 11:04 am |
JrZook wrote: Well to check that weak spark see if you can just clobber something together to test how far it can jump without shocking yourself. The breakdown voltage for an air gap of 1cm between 2 electrodes is roughly 30kV. Stock stuff should be able to jump that. Also check the voltage at the coil. Should be very close to the battery voltage. No way in the wide world would this spark jump 10mm - it can barely crawl across the spark-plug gap of 25tho. I really don't think it can spark at all under cylinder pressure. I have to go to the dentist in Dubbo tomorrow to pick up my new teeth (in my trusty old FORD Econovan) 350ks each way and will be staying down there over night so will pick up a set of plugs and a distributor cap while I am there maybe even a rotor button then the whole lot will be new.
JrZook
 Posted: Wed Nov 14, 2012 11:20 am |
Was that directly from the coil? If so then you can eliminate the dizzy cap and leads. Since you have replaced the coil and ignitor already then it could be narrowed down to the source voltage to the coil or the ignitor triggering circuit..
Blakey
Joined: Sun Mar 04, 2012 6:11 pm Posts: 464 Location: Brisbane, Petire
 Posted: Wed Nov 14, 2012 11:33 am |
JrZook wrote: Well to check that weak spark see if you can just clobber something together to test how far it can jump without shocking yourself. The breakdown voltage for an air gap of 1cm between 2 electrodes is roughly 30kV. Stock stuff should be able to jump that. Also check the voltage at the coil. Should be very close to the battery voltage. its 33kV for 10mm on round electrodes, it can be much less to as little as 10kV per 10mm for different electrode shapes, and example being a jacobs ladder. which can use as little as 9kV. but at higher pressures the dilectric strength of air is greaty increased. and 30kV could go as little as 1mm
