It is currently Mon Aug 03, 2026 11:01 pm
Post Posted: Sat Dec 01, 2012 11:32 am
Hi all
I just got a 2nd lift kit 2 inch suspension lift kit. It does not comes with instructions.
Just wondering what's the easiest and simplest way to install it for a noob like me?
What to avoid and must do ?
Vehicle: 95 sierra
Post Posted: Sat Dec 01, 2012 11:41 am
viewtopic.php?f=37&t=37080
Vehicle: 95 sierra
Post Posted: Sat Dec 01, 2012 11:42 am
I did mine the other day with no experience aswell it's pretty self explanatory when you take out the old kit. Just put it back in the way you took it out. Just be careful when taking the U bolts off that the diff is supported
Post Posted: Sat Dec 01, 2012 11:50 am
Do you remove the leaf or suspension first ?
Post Posted: Sat Dec 01, 2012 11:57 am
For a start what vehicle is this for? No point giving advice for a sierra if you own a jimny.
Post Posted: Sat Dec 01, 2012 12:00 pm
Its for a Sierra.
Vehicle: 95 sierra
Post Posted: Sat Dec 01, 2012 12:10 pm
I took the leaf out first, I don't think it really matters
Post Posted: Sat Dec 01, 2012 1:07 pm
It's for a 1989 sierra
Post Posted: Sat Dec 01, 2012 1:08 pm
Any dos or donts?
Vehicle: 95 sierra
Post Posted: Sat Dec 01, 2012 1:16 pm
Just support the axle at all times and make sure you grease up all the bushes. Make sure the u bolts are tight, you'll probably have to get a wheel alignment after, I had too
Post Posted: Sat Dec 01, 2012 1:24 pm
Shouldn't need a wheel alignment, as a lift kit doesn't change any of those things. Make sure you use proper jack stands, if it falls on you it will hurt. A lot. :lol:
Post Posted: Sat Dec 01, 2012 1:36 pm
Man how do people push the metal sleeves into the bushes ....?
Vehicle: 95 sierra
Post Posted: Sat Dec 01, 2012 2:30 pm
Grease and rubber mallet
Vehicle: Vit swb 95
Post Posted: Sat Dec 01, 2012 3:51 pm
Check out my build thread, shows how i did it with a little $20 vice :D
Post Posted: Sat Dec 01, 2012 6:54 pm
Thanks guys. Also how do people attached garden edging to extend the flare to fit wider Tyres? Mine is a 1989 wt
Post Posted: Sat Dec 01, 2012 7:55 pm
The axles shouldn't need any more support than the wheels and tyres already provide... You don't need to take the wheels off to change the springs and/or shocks.
It is the rest of the car IE: The chassis, that will need supports (stands) under it.
No wheel alignment is necessary.
Vehicle: 1985 lwb sierra UTE
Post Posted: Sun Dec 02, 2012 6:56 am
Just be careful and go slow, like want33s said leave the wheels on don'ttouch the brakes or tail shts ether
Post Posted: Sun Dec 02, 2012 11:32 am
Cool will give it a crack today ..thanks ppl
Post Posted: Sun Dec 02, 2012 8:43 pm
Manage to complete the front this afternoon . Got some issues putting the unbolts back to the plate but after mucking around for like an hour manage to get it in. Do you guys remove the sway bar ?
Hopefully the rear will be easier ...
Post Posted: Mon Dec 03, 2012 4:55 am
Yes take the swaybar off.
Vehicle: 85 Suzuki Sierra
Post Posted: Mon Dec 03, 2012 10:07 am
I put the ubolts in a vice to bend them in a bit so they drop right into the holes, which is a lot easier than trying to squeeze them in under the car.
Orange LWB Sierra
Post Posted: Mon Dec 03, 2012 1:05 pm
i manage to get the sway bar on..
is it a good thing to remove it or ?
Post Posted: Tue Dec 04, 2012 5:11 am
You might as well, all it does is restrict flex, it will handle fine with it off.
Users browsing this forum: No registered users and 75 guests
