| Author |
Message |
alexxx
Joined: Sun Aug 05, 2012 9:49 pm Posts: 823 Location: Adelaide
Vehicle: Ford Maverick 4.2 Diesel
 Posted: Sun Dec 02, 2012 7:36 pm |
Well that's 2 for the gv sliders. Anyone else want to join in for a group purchase???
Fatzook
 Posted: Sun Dec 02, 2012 9:42 pm |
I already have the chassis brackets for the GV. I just need to get the donor car from my mate for a few days. Its a LWB though, so anyone wanting shorty sliders will need to provide me with a donor car for 2 days. Also it would be better for me if there were 3 or 4 people wanting them, as its easier to justify the time and expense of making a Jig.
alexxx
 Posted: Sun Dec 02, 2012 9:58 pm |
i can put the word out there. both mine and chops are lwb GV's. anyone else interested??? any idea what wed be looking at price wise?
thanks buddy
wagola
Joined: Wed Apr 21, 2010 11:30 pm Posts: 7 Location: Adelaide
 Posted: Sun Dec 02, 2012 10:11 pm |
id also be pretty keen for some LWB sliders for the GV
alexxx
check new topic in suzuki talk
GeckoXL7
Joined: Tue Sep 25, 2012 8:12 pm Posts: 1173 Location: VIC
Vehicle: 2002 Suzuki XL7
 Posted: Mon Dec 03, 2012 8:25 am |
Ive been after XL-7 ones for a long time, people say the GV ones dont fit, i just think they will be slightly shorter?
EG GV sliders are 1800mm long i dont know if that is from end of door to door or wheel arch to wheel arch.
On the XL the doors 1800 at bottom and wheel arch's are 1990mm. Its possible the center Tail shaft support bearing cross member may be a issue with mounting depending on where the mounts are.
The only ones available is just a 3" tube which my misses refuses me to get as she said might as well have nothing, and i think the price people charge $745 is a bit steep just for 3" tubing.. (she needs a step)
I thought of making my self up some out of 2" galv pipe 6mm thick with a alloy checkerplate on top. Will the pipe be thick or strong enough?
Just thinking, some may think its stupid, but how about the Sliders on some heavy duty hinges prob 10mm high tensile bolts, and heavy duty springs to hold it up, so i could step on the steps to lower them so kids can jump in, then when need they spring back up.
Fatzook
 Posted: Mon Dec 03, 2012 8:43 am |
You would need to make a set specifically for the XL7. Like you said, there is a difference in length, and there may be extra obsticles to dodge.
I'd use a 40NB medium pipe for the main slider rail, 40NB legs, back to atleast! 3 chassis mounts per side. Any step or kicker bar could be 32NB medium pipe.
GeckoXL7
 Posted: Mon Dec 03, 2012 9:27 am |
Great thanks.
I was thinking of 4 mounts, want it to be solid, as the long wheel base likes collecting big rocks usually by the rear wheel.
I will have to go back and see if got 40NB, The 50x6mm pipe wasn't that expensive, comes in 6m lengths and they will cut to suit think $5 per cut, just not to sure how heavy it will be.
Fatzook
 Posted: Mon Dec 03, 2012 8:40 pm |
GeckoXL7 wrote: just not to sure how heavy it will be. Heavier than it needs to be. But if you already have it.......
Fatzook
 Posted: Thu Dec 13, 2012 5:35 pm |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13013 Location: Melbourne
 Posted: Thu Dec 13, 2012 5:42 pm |
sbyard
Joined: Sat Oct 10, 2009 10:30 pm Posts: 189 Location: Perth, WA
Vehicle: 89 Softtop Sierra, 6.5's, 30's
 Posted: Thu Dec 13, 2012 8:21 pm |
DarkHorse
 Posted: Thu Dec 13, 2012 10:41 pm |
Ooo, fancy!
Gotta ask - why bolts over the chassis as well as the horizontally split mounts?
harry loane
Joined: Mon Oct 01, 2012 7:11 pm Posts: 86 Location: wauchope
Vehicle: 1986 sj50 suzuki sierra
 Posted: Thu Dec 13, 2012 10:44 pm |
How much would they set me back
Fatzook
 Posted: Thu Dec 13, 2012 10:51 pm |
DarkHorse wrote: Ooo, fancy!
Gotta ask - why bolts over the chassis as well as the horizontally split mounts? The large piece is a VERY snug fit on the rail. It gets bashed on with a hammer. The small peice that the slider is mounted to, just sits there. This makes it easier to fit/ remove them. The small bolts on the side hold the 2 together, and the bolts over the chassis rail cramp the bracket against the rail.
Fatzook
 Posted: Thu Dec 13, 2012 10:55 pm |
sbyard wrote: I'll take two They only come in pairs
Fatzook
harry loane wrote: How much would they set me back How much do you want to pay?
harry loane
 Posted: Thu Dec 13, 2012 10:59 pm |
Seeing as I have no money probs not much hahah
Fatzook
 Posted: Thu Dec 13, 2012 11:06 pm |
harry loane wrote: Seeing as I have no money probs not much hahah Thats a bit less than what I charge
harry loane
 Posted: Thu Dec 13, 2012 11:32 pm |
Bucketload
Joined: Sat Feb 12, 2011 11:34 am Posts: 236 Location: Perth
 Posted: Thu Dec 13, 2012 11:58 pm |
If I understand right the theory is that the bolts holding the sliders onto the chassis need to pretty beefy for the sliders to work but also the weakest link to prevent damage to the chassis rail so that the bolts are the first thing to give – or have I got this messed up? I am guessing M12 8.8 would be in the ballpark?
Fatzook
 Posted: Fri Dec 14, 2012 7:31 am |
To be honest, there is no science behind my design. Its born of convenience more than anything else. The 2 piece bracket is cheaper to fold ( a single 'U' shape bracket requires special tooling in the press), and its easier to work with, despite the extra bolts up the side of the bracket.
Oh, and the 32NB tube will bend WELL before those bolts give out.
sbyard
 Posted: Fri Dec 14, 2012 9:19 am |
Fatzook wrote: sbyard wrote: I'll take two They only come in pairs  Haha, well what are we looking at cost-wise? I'm interested fo shizzle ma nizzle Sam
Gough
Vehicle: 99 JLX Suzuki Jimny
 Posted: Sun Mar 24, 2013 6:45 pm |
I'm in Sydney with a 99 jimny, got any designs and prices for my car ?
Nick.storm
Vehicle: Vitara 1997
 Posted: Mon Apr 01, 2013 6:44 pm |
So im thinking about some basic sliders, i dont want them for steps but just for some protection and a place to lift my car with a high lift jack. What are your thoughts on this design? ill probs curve in the ends. Nothing is to a real scale im just tossing around with designs at this stage. Attachment: sliders.png
douglasgiersch
Joined: Thu Mar 15, 2012 4:40 pm Posts: 283 Location: Lowesdale Southern NSW (Close to Albury)
Vehicle: 82 Sierra SWB soft top
 Posted: Wed Apr 03, 2013 5:28 pm |
If your planning on using them to use with hi lift maybe something to retain the hilift in place? I've seen a ute slide whilst be jacked by its tray and it moves dam quick.
Nick.storm
 Posted: Wed Apr 03, 2013 5:43 pm |
Yeh that's a good point! Ill have to think about that cos they need to be flat/smooth enough to slide on rocks as well
dano_mung
Joined: Sun May 17, 2009 11:30 pm Posts: 237 Location: Brisbane
 Posted: Sat Apr 13, 2013 10:34 pm |
Fatzook wrote: What size bolts did you use on these mr fatzook? (the bolts through the body mount outrigger) Thinking of making something similar for my roza as it has very similar outriggers. If you could PM me an estimate for a set the same as those pictured or if you don't have the time to do the whole lot perhaps just the mounts as I reckon I could fab the rest on my own mostly.
PORL
Joined: Fri Sep 17, 2010 8:42 am Posts: 262 Location: Beeliar WA
Vehicle: 2004 Jimny 1.6
 Posted: Tue Apr 16, 2013 8:15 pm |
Gough wrote: I'm in Sydney with a 99 jimny, got any designs and prices for my car ? I'm WA and keen also man
harry loane
 Posted: Tue Apr 16, 2013 8:20 pm |
i drew these up what do you guys think
