It is currently Tue Nov 03, 2026 4:02 am
Vehicle: LPG 1.6 Sierra
Post Posted: Mon Dec 03, 2012 2:50 pm
I'm wondering hard how cast alloy is to weld, because if I can i'd like to have this throttle body welded directly to this intake manifold. I do have a DIY adaptor plate, although no plate = more vertical clearance (current setup is rubbing on bonnet underside). But - the cast walls are thin, it'd be hard to poke a tig welder around the joint, and i'm scared that the throttle body may warp slightly enough to become useless.
What do you guys think? Get it done or quit while i'm ahead?
Post Posted: Mon Dec 03, 2012 2:53 pm
i personally wouldnt, you would be better off designing a lower profile adapter plate.
Post Posted: Mon Dec 03, 2012 3:07 pm
Here's my problem - i'm getting a little bit of rub on the underside of my bonnet from this point on the air hat.
The intake setup in the first post photo is 15mm lower than in the second pic - put in an adaptor plate and it's taking away a clearance advantage I could gain.
Post Posted: Mon Dec 03, 2012 3:12 pm
is there a lip on the bottom of the hat you could trim down.
how thick is the adapter. i would think you could make up a 6mm adapter easy enough.
15mm seems exxessive
Post Posted: Mon Dec 03, 2012 4:15 pm
If rubbing/clearance is an issue why not lower your engine by elongating or re-drilling the mounts? Wonder how good those alloy brazing rods would work on this?
Post Posted: Mon Dec 03, 2012 4:55 pm
make a 90' adaptor?
Post Posted: Mon Dec 03, 2012 5:08 pm
http://www.muggyweld.com/?view=super5 - looks like the perfect stuff for the job! I'd be game to try that.
I just went to a workshop in Wangara - he said the best idea would be to keep it two piece for ease of repair, to plane off the the cast carby base plate and weld on a new adaptor face. Makes sense - then i'd have plenty of clearance up my sleeve. But, I got the idea he'd rather someone else do the welding... I guess welding 2mm cast alloy isn't exactly childs play. But I've seen enough welding in the last year to know it can be done.
Post Posted: Mon Dec 03, 2012 5:35 pm
bonnet can easily be lifted a few mm
It also may only be a cross rib catching, which could easily be love tapped or notched
Vehicle: 1985 lwb sierra UTE
Post Posted: Mon Dec 03, 2012 5:38 pm
could u dint in on that spot,or cut it and fold the original material back down and weld it back on
Vehicle: Getting parts atm
Post Posted: Mon Dec 03, 2012 6:43 pm
Cast alloy is crap to weld without decent heat which will prolly warp it..
Post Posted: Tue Dec 04, 2012 7:31 am
How thick is your adapter now?
Post Posted: Tue Dec 04, 2012 1:07 pm
How about devcon or similar? pompoms
If you can find a spare manifold and dont mind experimenting- I have a spare tin of the "devcon-ish" stuff we use to glue drill rods to hammers for blast hole drilling.
The "devcon-"ish stuff was so strong it would hold for thousands of hours of use on a drill rig- being hammered continually the whole time.
To remove the hammer or coupling when it failed the fitters would have to heat it up with an oxy torch until the steel of the hammer assembly and drill tube were cherry red- then use reverse rotation to unscrew them.
Even then, quite often the steel drill tube failed before the "devconish" stuff let go.
I reckon if you can find an old manifold- we can do a cut- and - shut and glue it together and see what happens.
If it works- all is good Armsup
If it doesnt- well, bung the original manifold back on, and think again.
gimme a call!
Stephen.
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Tue Dec 04, 2012 8:39 pm
Just get the old holes on the manifold filled up and a bit of material added to the sides and tap some new holes for the studs.
Post Posted: Thu Dec 06, 2012 10:02 am
gimme a call!
Stephen.
I have a plan, but two heads are better than one - i'll buzz ya when i'm back. I'll give it a try around middle of the month - work will have me in Exmouth for a week or so in the meantime.
Post Posted: Thu Dec 06, 2012 5:47 pm
no worries Tim,
work has me trundling up and down the highway and all over the place- so when you are ready, either text, PM, smoke signals or whatever will do.
stephen
Post Posted: Fri Dec 07, 2012 6:34 am
I'd look at the other idea's first, dropping engine/trimming some of the plenum/trimming bonnet/90* adaptor...
Can you get the manifold, TB and adaptor or shaved down a couple mm each?
Vehicle: chick magnet coily
Post Posted: Sat Dec 08, 2012 6:38 pm
cut a hole in the bonnet and put a scoop over it ;)
Post Posted: Sat Dec 08, 2012 8:27 pm
Wonder how hard it would be to modify the manifold for sidedraft entry like the guys do in the states for the my-side harley carb kits. Flow characteristics would improve nicely over the downdraft stock setup.
Users browsing this forum: No registered users and 279 guests
