It is currently Fri Jul 31, 2026 8:20 pm
Post Posted: Tue Dec 04, 2012 11:27 am
Hi guys, i have search a bit and some of the people use garden edging from bunnings to extend the flares..
i am just wondering how you guys mount the garden edging ?
Post Posted: Tue Dec 04, 2012 11:29 am
I used screws, it gets ripped off really easy if you rub a bank or something.
Post Posted: Tue Dec 04, 2012 12:54 pm
so the rubber from clark rubber is betteR?
Post Posted: Tue Dec 04, 2012 1:21 pm
A friend used tek screws, another one used tek screws through beer bottle caps to spread the load. On my cars a combination a rivets and tek screws through plate cut to size hold the flares on.
Clark Rubber are expensive, find a rubber supplier and it will be cheaper. :)
Post Posted: Tue Dec 04, 2012 1:46 pm
I attached mine with hopes & dreams
I think I used 25 screws & washers on each wheel arch.
Post Posted: Tue Dec 04, 2012 2:24 pm
any suggestion from WA?
Vehicle: Twin cam 1300 gti engine.
Post Posted: Tue Dec 04, 2012 4:11 pm
Holy shit!! I think I used about 8 on each arch.
Bought 65x6mm rubber from the great outdoors shop for about $30 and allowed 1m per arch on my sierra. Works a treat!!
Vehicle: Jeep
Post Posted: Tue Dec 04, 2012 4:38 pm
The stuff from Clark Rubber, is proper wheel arch flexi flares, it comes in 50 and 75mm, and is not as hard as garden edging, last time i saw it, it was about $12 per metre, and, IMO, looks much better... :D
I tried to find it on the Clark Rubber website, but cant remember what they call it now... but i found some on ebay -
http://www.ebay.com.au/itm/50MM-FLEXIBL ... 3cc989f7ed
http://www.ebay.com.au/itm/FLEXIBLE-FLE ... 1c2d2356dd
Or the full list of whats available on ebay -
http://www.ebay.com.au/sch/Vehicle-Part ... are&_rdc=1
Post Posted: Tue Dec 04, 2012 5:22 pm
so many choice !!!
Post Posted: Wed Dec 05, 2012 10:47 am
$24 a metre the last time I saw it!
Post Posted: Wed Dec 05, 2012 12:42 pm
how many meters is needed for a zook?
Vehicle: Jeep
Post Posted: Wed Dec 05, 2012 2:07 pm
Looking at some of the listings on ebay, they all have 3mtrs for two wheels, so all 4, allow 6mtrs all up, and you should be fine... :D
Post Posted: Wed Dec 05, 2012 2:17 pm
Measure around the edge of your wheel arches mate. :)
Post Posted: Wed Dec 05, 2012 3:06 pm
a touch over 4m should do your zook.
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Dec 05, 2012 9:02 pm
I dunno bout where you are but Clark rubber is about the ONLY rubber supplier that I know of lol
Post Posted: Tue Dec 11, 2012 4:29 pm
bunnings is like 15 bucks for 20 m so when you tear a bit off you screw a new one on!!
oh yh and just use normal metal self tappers
Vehicle: sj51
Post Posted: Tue Dec 11, 2012 5:34 pm
Nutserts work well as long as you have sufficiant area for them
Post Posted: Wed Dec 12, 2012 3:42 pm
nutserts looks too big for the WT Stock flares ay
Post Posted: Wed Dec 12, 2012 5:23 pm
You can get different sizes of nutserts. But nutserts seem like a lot of. Effort
Vehicle: sj51
Post Posted: Thu Dec 13, 2012 10:48 am
Have ever fitted a nutsert?
Drill hole,
push nutsert in hole,
squeeze handle once on nutsert tool,
Done...
Im missing the effort bit :?
Post Posted: Thu Dec 13, 2012 5:50 pm
Garden edging is awesome because it holds its shape well and is tough, but it's also hard on the car. It's very strong- typically stronger than the guard its bolted to, so it's not uncommon for the garden edging to cause damage to the guard if you bump a bank with the flare.
I use it, and I'm happy, but it would be nice if we could get the 4.5" wide rubber flare material that's available in the US.
Post Posted: Thu Dec 13, 2012 6:30 pm
Drill hole,
Done...
I use them a lot at work (stainless steel fab) and its more effort compaired to self tapping screws which is what I used.
Vehicle: sj51
Post Posted: Thu Dec 13, 2012 8:04 pm
Benny90 wrote:
Drill hole,
Done...
I think your missing my point,
i'll be blunter..
If someing like a nutsert is to much effort... i can only imagine the effort and kwality that go's into ones workmanship
Post Posted: Thu Dec 13, 2012 8:18 pm
I have clark rubber type flares on my trailer, look good, strong enough,
but a down side is that they stick to stuff, rather than slide over stuff.
Will be replaced with something slippery one day.
I had bunnings garden flares on my Sierra,
very good.
I solved the problem of them them damaging the panels
by trimming off the stiffening ridge on one side,
gave them more give
Vehicle: sj51
Post Posted: Thu Dec 13, 2012 8:29 pm
very good.
gave them more give
Good tech!
I like
Post Posted: Fri Dec 14, 2012 4:04 am
pezz wrote:
Benny90 wrote:
Drill hole,
Done...
i'll be blunter..
You have no idea. I was only stating that because there are easier quicker ways of doing it.
And as for quality and effort. Mate I work will stainless steel all fucking day, I have to put all of my effort towards it and make sure the finished product is 110% so go question someone else workmanship.
Vehicle: sj51
Post Posted: Fri Dec 14, 2012 5:14 am
Breathe deep, think calming thoughts...
Point me to the bit where i discredited your workmanship with stainless steel..
by the way, if it is done to 110% that means it isnt to the design spec as something can only comply 100%
Next time i get a tech screw in my tyre ill think of your zuk ;)
Chill out :)
Edit: tech screws are a pet hate of mine, they arnt designed for automotive use as far as im concerned
vibration is there worst enemy..
im genuinely sorry if i offended you.
Post Posted: Fri Dec 14, 2012 9:04 am
That was a bit out of line sorry mate. Just pissed me off.
Vehicle: sj51
Post Posted: Fri Dec 14, 2012 11:05 am
No worries...
Post Posted: Thu Dec 20, 2012 4:19 pm
I have the bunnings flares on mine just tech screwed to the w/t flare very durable and Ive rubbed them up against the bank many times with no damages to the pannel work.
 Profile YIM
Users browsing this forum: No registered users and 147 guests
