It is currently Wed Nov 04, 2026 4:23 am
Vehicle: 1999 Jimny
Post Posted: Thu Dec 06, 2012 6:41 pm
As stated above how the hell do you tighten the rear door to improve the seal???????????????
Post Posted: Thu Dec 06, 2012 6:48 pm
Undo the catch (loop on the car) and move it over
Vehicle: 1999 Jimny
Post Posted: Thu Dec 06, 2012 6:53 pm
doesn't appear to be any slide room Mr.Scrawn
Post Posted: Thu Dec 06, 2012 8:46 pm
I have/had the same problem. There is no allowable movement in the striker mech.
I ended up sticking neoprene rubber around the door to push against the rubber door seal on. This compressed the door seal and helped prevent door movement.
Post Posted: Fri Dec 07, 2012 2:46 am
I've used self adhesive weatherstrip around the door opening of the body - there's usually a rub mark where the door seal no longer seals that you can follow.
Post Posted: Fri Dec 07, 2012 5:16 am
Have you had it off to check? Quite often it doesn't look like it but there is. Not sure with Suzukis tho
Post Posted: Fri Dec 07, 2012 9:37 am
why not just replace the seal with a bigger one?
Post Posted: Fri Dec 07, 2012 11:11 am
Yes I have - on a GV the loop has perhaps 1/16" of movement.
Vehicle: 1999 Jimny
Post Posted: Fri Dec 07, 2012 7:18 pm
the door is a tad loose, the seal isn't rooted, maybe I will just modify the bastard....lol.
Post Posted: Fri Dec 07, 2012 7:55 pm
Have you tried turning the round black platic/rubber locator on the body? its actually adjustable by loosening the bolt and turning because its off centre.
Post Posted: Fri Dec 07, 2012 7:59 pm
same set up as the vitara. :wink:
Post Posted: Fri Dec 07, 2012 11:34 pm
Doesn't seem to affect the sealing that much, it does have a big impact on the rattle - what you end up doing is adjusting the rubber buffer to hold the door against the striker (the loop) so that it does not rattle, and let the seal do it's own thing - if it's too flat to seal properly, that's when you need the weather stripping.
Post Posted: Sat Dec 08, 2012 8:10 am
or as i said it the seal has been squashed and isnt sealing just go buy a new one. You can buy the stuff online or at Clark Rubber..
If the door is out of alignment then i think there is a little bit of adjustment at the hinges and striker. If this is not enough then you need to manipulate the door itself. Ive had to bend the top glass section on mine forward as it was leaking. Be carefull not to flex the glass as i can break, bend it at the base of the glass where it sits on the main body work.
Users browsing this forum: Google [Bot] and 114 guests
