It is currently Tue Nov 03, 2026 8:38 pm
Vehicle: Vitara G16b , Sierra G16b
Post Posted: Fri Dec 07, 2012 2:24 pm
Hi, I finished installing 6.5 gears in a transfer but it seems its in neutral when selecting 2H 4H. When I turn the input I can hold the output from spinning. I have tripple checked the linkage location and also pulled the box to bits twice.
How ever when it's in 4L everything sweet...Cant stop any of the flanges from spinning like you should.
Everything is shimmed nicely too.
Will it come good when I put it in the zook and drive in 4L for a bit?
Has anyone else had issues like this with transfers?
Thanks
Post Posted: Fri Dec 07, 2012 2:38 pm
are you sure you don't have your hi/low shift fork on backwards ? are you able to select your full shift pattern.
do you still have your 2wd/4wd-hi/low interlock pin fitted ?
Post Posted: Fri Dec 07, 2012 2:47 pm
oozuk wrote:
are you sure you don't have your hi/low shift fork on backwards ? are you able to select your full shift pattern. Yes I'm postive it's ok. Full shift pattern normal.
The one underneath? Detent ball and spring? Yeah maybe its somewhere here causing the problem. Even put a new spring in.
Also checked all the shift balls and springs with the case apart.
Post Posted: Fri Dec 07, 2012 2:54 pm
yeah the shift fork in the middle of the hi/low gears.
have you got a shifter bush installed ?
Post Posted: Fri Dec 07, 2012 2:59 pm
Shift fork is in the right location where is goes onto the shift collar. Got the collar on the right way too... (one side has a tapered edge.)
New bush installed.
Post Posted: Fri Dec 07, 2012 3:01 pm
did you make sure you put the roll pin back in the shift fork that holds it to the shirt rod?
Post Posted: Fri Dec 07, 2012 5:50 pm
yes I did ^
Post Posted: Fri Dec 07, 2012 6:23 pm
I'm using a 1ltr transfer lever/stick too. Not sure if they are different to WT?
Post Posted: Fri Dec 07, 2012 6:35 pm
I'm such an idjit. Put the high speed output gear on wrong way round. The shift collar wasn't grabbing it that's what it was! lol
Post Posted: Fri Dec 07, 2012 8:06 pm
glad you sorted it ;)
Post Posted: Fri Dec 07, 2012 9:26 pm
Cheers mate, thanks for trying to help. :)
Users browsing this forum: Google [Bot] and 102 guests
