It is currently Sat Sep 26, 2026 4:33 am
Vehicle: 89 SWB vit
Post Posted: Mon Dec 10, 2012 12:42 pm
Hey Everyone,
Over the weekend i decided to turn the AC on to keep the dogs cool while we took them to the beach.
The majority of the time with the AC switched on it just felt like all I'd done was turn the fan on. No cool air at all.
So my question is does my air con needs some fixing or are the old vitara AC's just not that good on hot days?
Vehicle: 96 vit hardtop
Post Posted: Mon Dec 10, 2012 1:13 pm
Should be good, maybe u just need to regas it.
Vehicle: 2002 Suzuki XL7
Post Posted: Mon Dec 10, 2012 1:25 pm
Yeah prob just needs a regass how long since you noticed it not blowing cold air?
I got my aircon serviced at
Jackson's Auto Repairs
252 Brighton Road, SOMERTON PARK
Phone: 8376 0899
Email Address: admin@jacksonsauto.com.au
Website: http://www.jacksonsauto.com.au
SA Mechanical
They saved me a bucket load of money 5 years ago, as some quoted between 2700- 4200 to fix a hose that rubbed against the core creating two holes, one hose was $370 from suzuki alone and needed two around $900 for the two. Plus dryer bottle and condenser (which are one unit) + O rings $1400 and Regass $350 (being a XL-7 i have two aircons so it requires alot of gass!) all up they charged $1740 and fixed the hoses by making up there own and even worked out why it happened and prevented it from happening again. I called every aircon service company in Adelaide and they where definatly way out in front of everyone else with knowledge and customer service. Even asked me to come back a few times to check the gass levels and top ups at no charge for a short period after to make sure there work was done right... cant beat that..
The 89 vit has a much simpler aircon than mine, regass would prob be around the $150mark if completely out.
Vehicle: 89 SWB vit
Post Posted: Mon Dec 10, 2012 1:57 pm
I was thinking regas but wanted to check if maybe they're just not a very good air con.
The weather was cold when I bought it so I don't think i bothered to check.
This is the first time i've really tried using it. Normally I just put the window down but the husky was giving me death stares so thought it would be in my best interest to try!
Post Posted: Mon Dec 10, 2012 2:18 pm
Lol, always comes down to the husky i know what you mean i need to fix my rear aircon as my husky always tries to get to the front of the car, i like to keep all the fluff flying around the back of the car and not in my face :P
Aircon service places can tell you pretty quick what to expect from your aircon, and give free quotes.
Post Posted: Mon Dec 10, 2012 9:06 pm
The overheat cut off sender wire may have fell off.
Or sender buggered.
It stops the AC running, but turns on its compresser fan
Are you sure compresser is spinning.
Post Posted: Mon Dec 10, 2012 9:08 pm
I regassed with HyCool gas.
Older gas systems need upgrading to run the new R34 gas,
but don't to run Hycool
Post Posted: Wed Dec 12, 2012 1:26 am
Hopefully just regas.
Compressor and/or condensor might have given up...30-odd year old components now.
Vehicle: 1995 2.0 V6 Vitara Estate
Post Posted: Wed Dec 12, 2012 7:49 am
I took my 95 Vitara to get regassed and was told it had gas but that it also had "an Electrical Fault"
What steps should I take to narrow the problem down?
Vehicle: 89 SWB vit
Post Posted: Wed Dec 12, 2012 8:35 am
Or sender buggered.
Compressors definitely coming on. The revs drop and you can hear it coming on just no cold air
Post Posted: Wed Dec 12, 2012 8:40 am
First check to see if the aircon light comes on, when turn on can you feel/hear the aircon turn on, if it does can you here the thermo fan come on.
As mentioned before there is also a Temperature control that controls the Evaporator Core temp in the car if it gets to cold it turns of the compressor but keeps the core at a preset temperature, its there to stop the core from freezing over. These fail which prevents the Compressor turning on or the gas getting through the Evap core.
Post Posted: Wed Dec 12, 2012 9:37 am
Aircon Light definitely comes on. Revs pick up but it doesn't sound like anything is working
Vehicle: 89 SWB vit
Post Posted: Fri Dec 14, 2012 10:35 am
Or sender buggered.
I had a quick look last night before it got dark. There were 2 wires, one that ran off into the loom and headed off to the drivers side and this little guy that was loose. Is this the wire mentioned above and if so where's he meant to live? :)
Post Posted: Fri Dec 14, 2012 11:13 am
Took pix of mine. Hope it helps.
Post Posted: Fri Dec 14, 2012 11:19 am
Would it be the Compressor Clutch wire?
Vehicle: 89 SWB vit
Post Posted: Sat Feb 02, 2013 8:59 am
going to have a look at this again today. I did see your pics and had a quick look when you put them up Christover. Just realised i didn't say thanks at the time, appreciate the effort :)
Users browsing this forum: No registered users and 24 guests
