It is currently Sat Aug 01, 2026 7:04 am
Vehicle: Twin cam 1300 gti engine.
Post Posted: Thu Dec 13, 2012 3:26 pm
Alright so I need a new radiator for my manual 95 sierra. Has a GTI twincam engine.
Every shop I call has little idea about it and have all given me odd sizes. So Im after the correct core size. Would a radiator from ebay be ok if it comes to that?
Cheers for any advice.
Post Posted: Thu Dec 13, 2012 4:31 pm
There are 4 different rads for Aust delivered Sierras.
1.0
1.3 up to 92? (I think)
1.3 92? to 96
and then Coily.
Vehicle: SJ51T
Post Posted: Thu Dec 13, 2012 7:09 pm
Why not upgrade to a vit or jim rad?
Post Posted: Fri Dec 14, 2012 3:54 am
Well that's on the cards. Just don't know which one.. I would like to go with one that is wider because there is room for one and I can fab some new mounts.
Would you be able to tell me which fits best?
Vehicle: sj51
Post Posted: Fri Dec 14, 2012 5:24 am
Best bet would be to find out the volume of the radiator of the swift your engine came from.
If the standard sierra one is larger, run with it...
if not, look for something that is.
Vehicle: SJ51T
Post Posted: Fri Dec 14, 2012 6:42 am
I'm using a Jimny rad with jimny powersteer next to it, it fits nicely.
31zook has made a vit rad (wider than jimny) fit as well, however, i'm not sure if he had powersteer or not. He did an excellent write up on it.
Post Posted: Fri Dec 14, 2012 6:59 am
If you are willing to move mounts, got a vitara radiator, shroud and viscous fan.
Steve
Post Posted: Fri Dec 14, 2012 9:01 am
Sweet cheers for the advice all. Going to sus it out this arvo. Will reply if I need to know more about it.
Vehicle: SJ51T
Post Posted: Fri Dec 14, 2012 12:07 pm
To put some usefull info in, this is 31zook's vit rad how to.
viewtopic.php?f=14&t=8269&hilit=rad+bracket
Post Posted: Sat Dec 15, 2012 8:53 am
Well serached a lot of places and autobarn have one that is a nice think 42mm 2row in standard width and hight for $310.I'm thinking that will work well in cooling the little beast?
Post Posted: Sun Dec 16, 2012 12:28 pm
Maybe... but a stock radiator will cool the car fine with a proper shroud and fan.
There's lots of debate about this stuff, but if you're starting from scratch, it would make sense to be to fit a radiator, shroud and fan combination from a car with comparable power, and comparable intended use as your car - which is why I suggested using a Vitara radiator fan and shroud.
Sure you can fit a thicker radiator, but if the fan and shroud aren't up to scratch you might not improve cooling very much at all for your $310.
Post Posted: Sun Dec 16, 2012 4:45 pm
Its never easy is it... I do believe the radiator from Autobarn will do the job. Will soon find out if the thermo fan works with it tho if not ill have to change it to a fan and shroud.
Thanka a lot for the advice all.
Vehicle: SJ51T
Post Posted: Mon Dec 17, 2012 4:32 pm
Change to a fan and shroud while the rad is out. Its easy enough with a GTI motor.
Post Posted: Sat Dec 22, 2012 11:39 am
I've got a swb vitara one in mine I had to change the mounts around.
But I put a g16b in so it was a good mod to keep it kool and its never over heated
Users browsing this forum: No registered users and 25 guests
