It is currently Fri Jun 05, 2026 6:09 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
Vehicle: 1.3 Tin Top
Post Posted: Sun Aug 26, 2012 12:52 pm
wouldn't be funny when it's embedded into your scull, to who ever said they use their towball for recoveries...
go kick yourself in the dick, repeatedly.
If your aiming that at me? i never said anything about towBALL. if you read carefully, you will see i asked about the tow BAR
Post Posted: Sun Aug 26, 2012 1:29 pm
nah mate, it was this joker i was telling to kick his own dick... :wink:
larry wrote:
Ill post a pic this arvo of how i use my towball for recoveries lol
Post Posted: Tue Aug 28, 2012 6:52 pm
aha, my apologies :)
Vehicle: 1985 lwb sierra UTE
Post Posted: Tue Sep 11, 2012 7:38 pm
Oh :shocked: I just kicked my self in the Dick oh man Atarri 4x4 u gota be more obiouse, were is the ice :cry:
Vehicle: chick magnet coily
Post Posted: Wed Sep 12, 2012 10:52 am
how did you kick yourself in the dick?
Post Posted: Wed Sep 12, 2012 11:04 am
:roll:
Post Posted: Wed Sep 12, 2012 11:07 am
Double jointed most likely...
Vehicle: LWB Sierra & XL7
Post Posted: Wed Sep 12, 2012 12:35 pm
alanbie wrote:
Recovery points
Where did you get these from?
Built or bought?
I think TSOR should make a batch of them.
'92 Vitara & Camper trailer
Post Posted: Tue Sep 18, 2012 8:10 pm
I made them, well, the laser cutter made them from my dxf.
Post Posted: Tue Oct 09, 2012 10:49 am
Uv heard hung like horse?
Well I'm not just removed shoe did it manually lol
Post Posted: Tue Oct 09, 2012 11:38 am
Grave dig much? I thought you had enough of this place??
Back on topic.
I think Mr Fatzook will be making the recovery lugs in the near future Armsup
Post Posted: Tue Nov 27, 2012 11:38 am
Back on topic.
Na just enough of dick heads....
Vehicle: '84 LWB 1LTR
Post Posted: Fri Dec 14, 2012 8:58 pm
Cut these out the other day out of 12mm MS. Shallow enough to be used with the standard front bar and leae the point assecable. Thats a Sierra brake pad next to it for size reference.
Haven't mounted them yet sill tossing up to go RUF or not. 2 extra 10mm holes will need to be drilled at the back for extra support.
Plan to have them mounted on the inside of the rail thoigh with crush tubes of course.
And this is the amount that would be needed to trim of the standard bar if I go ahead with it and not do the RUF.
All up its only a 45mm by 14mm notch that needs to be removed. And the recovery holes should sit about 40-45mm below the standard front bumper :) Leaving a very tidy fromt end with good recovery points :)
Vehicle: F10a tin top ferociously stock
Post Posted: Mon Dec 17, 2012 5:13 pm
I used to occasionally snap 50mm balls on beaches just towing boats out if I went a bit hard - mind you I was using a 5 tonne tractor as a commercial fisherman...
There is no way I want to be near anyone trying to skull drag more than a small trailer using a tow ball - seen one pass straight through the back window, then the front window, then back through the front window on the whip and embed itself in a passenger headrest - good job no passenger that time. Also note a woman killed a while back on a beach here in Australia - hit in the throat by half a towball, must have been realyl great for her kids to see that - I don't think it was a freak accident, just stupidity.....
http://www.abc.net.au/news/2011-08-21/f ... nt/2848762
The threaded stub on a 50mm ball looks like it would handle anything, but the leverage from the ball even with the shoulder firmly set against the towbar tounge easily reduces the shear resistance to a fraction of what you think under shock loading. Remember we are talking a $10 lump of machined steel - it is neither hardened nor is it high tensile. I wouldn't expect a towball to have half the stength of one full test high tensile 10mm bolt...
Post Posted: Fri Jan 04, 2013 8:25 pm
Also you guys might want to consider snatch strap ratings! if you use a to highly rated strap (eg: 10,000kg) on a light car (suzuki) you wont get enough stretch to reduce the shock load of the recovery which will cause damage
Vehicle: sj51
Post Posted: Fri Jan 04, 2013 8:31 pm
X2.... the snatch strap should be matched to the lighter rig of the snatcher and snatched
Post Posted: Fri Jan 04, 2013 8:39 pm
^^^ BCF do a zook weight snatch strap. http://www.auszookers.com/forum//viewto ... bcf+snatch
Post Posted: Fri Jan 04, 2013 8:48 pm
Dead right Pezz i use a 5T unit still pulls cruisers and poopootrols
Post Posted: Sat Jan 05, 2013 9:26 am
^^^ BCF do a zook weight snatch strap. /viewtopic.php?f=1&t=19119&hilit=bcf+snatch
supercheap also sells a 5000kg snatch strap (ridg rider) for $40
