It is currently Sat Aug 01, 2026 12:26 pm
Post Posted: Mon Dec 17, 2012 11:39 pm
Hey everyone,
Just in the process of putting a g16a into my suzuki sierra.. It's almost done now, but I just needed some help with a few wiring/sensors.
Could any one please tell me where I should connect these wires (on the g16 engine) to my sierra loom..
also, Is this an idle up or for something else.. Also if it's for something else do I need to connect it?
Cheers, Ni
Post Posted: Wed Dec 19, 2012 1:26 am
anyone??
Post Posted: Wed Dec 19, 2012 4:07 am
Does the engine run without either of those things? Top one could be something to do with fuel cutoff maybe? If you are stuck, you could use the carby off the G13 until you can get it sorted.
Post Posted: Fri Dec 21, 2012 1:09 am
Hey mate,
Did some testing with a multi meter and ended up that the green wire coming down is to connect to the front Temp sensor and solenoid, otherwise once the car heats up , it stalls..
The rear one (second image) hasn't seemed to have made a change. I was thinking it could have been something to do with an aircon solenoid..
Post Posted: Fri Dec 21, 2012 3:25 am
So it's all sorted then? 1600=lots power. Armsup
Users browsing this forum: No registered users and 86 guests
