It is currently Thu Oct 29, 2026 7:04 pm
Vehicle: 2004 suzuki jimny
Post Posted: Wed Dec 19, 2012 1:03 pm
Has anyone else had the problem of the 4wd light flashing once having 4wd engaged? in either high or low range?
Vehicle: 2002 Suzuki XL7
Post Posted: Wed Dec 19, 2012 1:41 pm
I got it when trying to engage 4wd when steering wheel wasn't straight or accidentally push 4wd Low when moving.
Could be a blocked, sticking or failing air actuator located behind front bumper, drivers side. Air pipe could even be leaking so what happens there is it presurises and looses pressure then represurises again so 4x4 never engages fully.
Does the light have a sequence or just continuously flash?
Post Posted: Wed Dec 19, 2012 3:46 pm
I put it in 4wd an there is a delay about 8 sec the the light starts flashing.
Post Posted: Wed Dec 19, 2012 7:36 pm
Vvt Jimny or non Vvt Jimny?
Most likely auto hubs failing to engage due to air leak.
Check vacuum hoses to swivel hubs.
The vacuum actuator is under the battery, not behind the bumper on a Jimny
Vehicle: Jimny
Post Posted: Wed Dec 19, 2012 7:46 pm
I had the problem the vaccume line from the head to the hub actuator was split. So go over you air lines
Post Posted: Thu Dec 20, 2012 4:32 am
Ok thanks guys.
Users browsing this forum: Google [Bot] and 76 guests
