It is currently Sun Oct 25, 2026 2:26 am
Board index » ausZOOkers » Website Help & FAQs
Post new topic Reply to topic  [ 262 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
Post Posted: Sun Jul 29, 2012 5:54 pm
viewtopic.php?f=5&t=23917&p=423302&hilit=fuel+pressure+psi+vitara#p423302
[quote="fordem"] The G16B in the 1.6 GV is 29.8~37 psi at idle, 35/6~42.7 psi with fuel pump operating and engine stopped. [/quote]
Post Posted: Sun Jul 29, 2012 6:36 pm
Noob question.
Can everyone see this area or just a few of the special people :-)
Post Posted: Sun Jul 29, 2012 6:48 pm
[quote="Bruce"]Noob question.
Can everyone see this area or just a few of the special people :-)[/quote]
I dunno why people don't use it, ya ask a question and grimbo gets ya the answer.
I need 43 +/- 5psi so it should be in the right range. Thanks grimtari
Post Posted: Tue Sep 04, 2012 9:41 pm
Guys im trying to a find the thread with all the vitara gearing options in it, i have found a set of vitara 5.62 diff ratios for sale over in the USA and thought i might post it in the thread so maybe someone here can buy them. i tried searching for it for ages and couldnt find the thread, if i remember correctly it has a few pages in it, not just a few posts.
here is the add: http://www.zukikrawlers.com/showthread.php?t=48636
cheers
Mitch
Post Posted: Tue Sep 04, 2012 9:44 pm
this is the only one i know of? :? viewtopic.php?f=17&t=6614&hilit=diff+ratio
Post Posted: Tue Sep 04, 2012 10:19 pm
yeah i saw that, im pretty sure there is another one somewhere. i couldnt find it myself, so thats why i asked. thanks anyway
Post Posted: Tue Sep 11, 2012 6:40 am
Excuse my lack of search ability, but are there any threads on the new shapeGV's with pros and cons etc?
Im looking at ridding myself of My BF MKII XR6 in exchange of a new type GV and want to know what models have what issues etc..
Thanks for your help in advance people
Post Posted: Tue Sep 11, 2012 6:58 am
[quote="Pubic"]Excuse my lack of search ability, but are there any threads on the new shapeGV's with pros and cons etc?
Thanks for your help in advance people[/quote]
I don't think so, well exept for threads with reasons why the diesels suck.
Post Posted: Tue Sep 11, 2012 7:05 am
Well then, I may just have to start one!
I have been looking through a few of the build threads and there are a couple I like.
Just want to firm up what issues are evident in the first of the new shape compared to the 07 models on wards.
Thanks Shep
Post Posted: Mon Sep 17, 2012 3:29 pm
Does anyone remember a thread about what degreaser to use in a parts washer?
Post Posted: Mon Sep 17, 2012 7:54 pm
[quote="shep"]Does anyone remember a thread about what degreaser to use in a parts washer?[/quote]
kero :D
Post Posted: Mon Sep 17, 2012 8:20 pm
Why does the quote button not work in this thread?
I can't use a solvent degreaser in my parts washer so kero is no good
Post Posted: Mon Sep 17, 2012 8:22 pm
[quote="shep"]Why does the quote button not work in this thread?
I can't use a solvent degreaser in my parts washer so kero is no good[/quote]
Works for me
No it doesn't
Post Posted: Mon Sep 17, 2012 8:25 pm
I use this stuff Shep
http://www.machineryhouse.com.au/Parts- ... ccessories
Post Posted: Tue Oct 02, 2012 12:22 pm
Any one know of any posts or photos regarding lifting up rear wheel carriers?
Cut and welded the one on the SV, but just want to see how others have tackled it on hard top vits/GVs.
With the 235/85 on the back it sits hard on the rear bumper, so really need to raise it 2 - 3cm to give it enough clearance. I could maybe get 1cm by redrilling the holes in the bracket, but that isn't going to be enough.
Tried searching but didn't have much luck.
Post Posted: Tue Oct 02, 2012 4:16 pm
FatZook did this for me a while back:
***Not letting me post [IMG] codes... WTF?***
First post on this page anyway: viewtopic.php?f=4&t=11477&start=300
Cut the flat mounting sections off and re-welded as high as it could with the existing steel. If you needed more it'd be a simple matter of some 25mm flat bar to replace.
Post Posted: Tue Oct 30, 2012 3:32 pm
Here's how I did mine (Jimny). Diagonal cut moved it up and out in one step.
http://auszookers.com/forum/viewtopic.php?f=4&t=16751&p=670877#p670877
Post Posted: Sat Nov 10, 2012 1:10 pm
Is there such a thing as a sierra rear transfer flange that doesn't have the handbrake stuff attached. Ie a rear flange with 8mm bolt holes to fit a 4wd light transfer
Post Posted: Tue Nov 13, 2012 10:00 am
Is there such a thing as a NT sierra rear transfer flange that doesn't have the handbrake stuff attached. Ie a rear flange with 8mm bolt holes to fit a 4wd light transfer
Vehicle: SJ51T
Post Posted: Tue Nov 13, 2012 10:26 am
Pretty sure i have one of those.. Got it off Bluesuzys WT LWB.
Vehicle: SWB Vit
Post Posted: Fri Nov 23, 2012 1:39 pm
Hi Guys, Can someone point me in the direction of some pictures of bar work around the fuel filler on a SWB Vitara (91 Shape).
Looking to go between the slider and rear bar... ?
Vehicle: chick magnet coily
Post Posted: Sun Nov 25, 2012 8:59 am
does anybody know the link to th airfilter/airbox thread?
Post Posted: Sat Dec 08, 2012 2:23 pm
Does anybody know where the tech articles have gone? Need to find the trailer plug diagram
Post Posted: Sat Dec 08, 2012 2:27 pm
http://www.britaxae.com.au/am/info_pages/britax-trailer-connector-wiring-diagrams.html
Post Posted: Sun Dec 09, 2012 12:21 pm
Hi,
New here so go easy :)
Just picked up my first 4wd on Friday (2005 GV - Manual 2.5) and have been looking around and searching pretty prolifically. Just wondering if there is a thread on problems these things can/do have? I will post a thread on my car and hopeful future upgrades in the next coupla days - any suggestions as to which thread to post this in as I will likely have many questions...
Post Posted: Sun Dec 09, 2012 2:18 pm
This isn't overly helpful, but in the spirit of Grimbo...
Click on the 'Rigs of Auszookers' section. Scan down the list for threads about GVs. Any thread over a couple of pages will probably give you a pretty good idea of what they are like to live with.
...and welcome! Nice looking GV.
Vehicle: 2002 Suzuki XL7
Post Posted: Tue Dec 18, 2012 10:23 am
Is there a thread on rear brake shoe replacements?
Adjuster and small spring fell off. Just need to know where everything goes. Suzuki Manual is useless.
If not i may have to work it out and make a new thread up.. Got the other wheel as a reference (Just hate springs!)
Post Posted: Thu Dec 20, 2012 10:35 am
I have had a look but can't find anything substantial/technical (most opinionative). Is there a thread on here regarding wheel spacers? I am intrigued at these and whether they are worthwhile or not (pro's vs con's)...
Post Posted: Thu Dec 27, 2012 7:03 pm
Worthwhile for what purpose?
Users browsing this forum: No registered users and 3 guests
