| Author |
Message |
ninjamoses
Joined: Mon Aug 13, 2007 11:30 pm Posts: 1787 Location: Butler, WA
 Posted: Mon Dec 17, 2012 11:57 am |
Just in the process of removing the transfer case at the moment and I'm trying (hoping) to do it without dropping the trans.
Just to be sure, where exactly does the transfer case end & gearbox begin? Is it the 12mm bolts which are in line with the back of the gearbox crossmember? Or is it the 14mm bolts in line with the front of the crossmember.
I was under the impression it was the 12mm ones (hence no need to remove the crossmember as its the gearbox which is bolted to that and not the transfer). If that is the case though, how does one get to the top bolt which appears to be underneath the gearstick tower/housing? I had read somewhere you had to remove the tower to get to it, but I cant actually see how you remove it (seems to be bolted from underneath/internally??)
Any other tips/tricks? Have already drained the case, removed the driveshafts, centre console and both gearsticks.
ninjamoses
 Posted: Mon Dec 17, 2012 12:04 pm |
Farkin, looking at the manual it appears to be the 14mm ones? That seems a hell of a lot more difficult to do that with it in the car still...
tanshi
 Posted: Mon Dec 17, 2012 12:06 pm |
its its the same as an older vitara i think the long one on the top still has to come out aswell as it holds all three layers.
Built4thrashing
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
 Posted: Mon Dec 17, 2012 6:50 pm |
have you tried removing the crossmember so you can lower the rear of the box a bit. Might be just enough to get the bolt undone.
DarkHorse
 Posted: Fri Dec 21, 2012 6:10 pm |
***the following assumes it's the same setup as an SE/SV Vit***
Crossmember out, you don't really have room otherwise. It's only 6 or 8 easily accessible bolts. Either strap the gearbox up to a bit of pipe or something through the holes in the tunnel, or jack under the gearbox.
Gearbox shifter housing has to come off - looking down the shifter hole the rear bolt is obvious, then there are two more either side further forward. (These are an absolute biatch to get to without a body lift. With the crossmember out I lowered the whole driveline a couple of inches until I could get my hands in.)
With the shifter housing off the centre bolt is obvious. It ties the transfer to the next two sections, so is about 3km long and takes ages to wind out. After that it's the 12mm rearward facing bolts that you need to undo. The two at the top corners are accessible from above, everything else from underneath. You'll need an extension to get at the bottom centre one unless you remove the mount.
shandy92
Joined: Tue Nov 25, 2008 10:30 pm Posts: 5066 Location: perth, Australia
 Posted: Sun Dec 23, 2012 1:49 am |
since this is a relevant step in the process, but how do the gear sticks come out? its one thing that i have never needed to do lol. something like push down and turn??
cheers
Jester
Joined: Fri May 08, 2009 11:30 pm Posts: 726 Location: Adelaide
 Posted: Sun Dec 23, 2012 5:42 pm |
shandy92 wrote: since this is a relevant step in the process, but how do the gear sticks come out? its one thing that i have never needed to do lol. something like push down and turn??
cheers lift the boot, and push down and turn the collar
DarkHorse
 Posted: Sun Dec 23, 2012 10:38 pm |
Keep track of the plastic bush thingy that sits around the end of the gearstick when you take it out!
shandy92
 Posted: Sun Dec 23, 2012 11:34 pm |
Jester wrote: shandy92 wrote: since this is a relevant step in the process, but how do the gear sticks come out? its one thing that i have never needed to do lol. something like push down and turn??
cheers lift the boot, and push down and turn the collar DarkHorse wrote: Keep track of the plastic bush thingy that sits around the end of the gearstick when you take it out!  thanks guys, any chance of a photo so i can identify the parts when i do it? or is the collar pretty obvious?
sideways
Joined: Fri Oct 29, 2010 1:53 pm Posts: 5943 Location: Northcliffe, W.A.
 Posted: Mon Dec 24, 2012 12:13 am |
shandy92 wrote: Jester wrote: shandy92 wrote: since this is a relevant step in the process, but how do the gear sticks come out? its one thing that i have never needed to do lol. something like push down and turn??
cheers lift the boot, and push down and turn the collar DarkHorse wrote: Keep track of the plastic bush thingy that sits around the end of the gearstick when you take it out!  thanks guys, any chance of a photo so i can identify the parts when i do it? or is the collar pretty obvious? Yeah it's pretty obvious, remove the boot and you'l see a steel collar, push the collar down and then turn it and it'l pop up and you can pull the stick out.
