It is currently Fri Oct 02, 2026 11:02 pm
Vehicle: SJ51T
Post Posted: Sun Dec 23, 2012 8:39 pm
Hey I'm chucking a stereo in my car and having a bad time trying to find which wire under the dash is the constant power.
I've tried a couple with no luck, seen the wiring diagram online but can't make sense which one is the constant live.
pretty sure it's white with no stripe (off the ignition) but would like someone in the know to confirm this as I'm sick of cutting the insulation off then taping it up.
Last edited by jonfromhamilton on Sun Dec 23, 2012 9:20 pm, edited 1 time in total.
Vehicle: SJ51T
Post Posted: Sun Dec 23, 2012 9:01 pm
choices are
white
white with black stripe
black with white stripe
black with yellow stripe.
Vehicle: SWB Sierra
Post Posted: Sun Dec 23, 2012 9:08 pm
White, without any trace might be a constant from memory.
Post Posted: Sun Dec 23, 2012 9:09 pm
Grab a simple/cheap wire/lead/cable tester (the one with the little light inside). Attach the alligator clip to a good earth, and stab the pointy end through the wire with the ignition off. If it lights up, it is constant power.
Vehicle: SWB Sierra
Post Posted: Sun Dec 23, 2012 9:12 pm
You can come over to my place tomoz if you need help.
Vehicle: SJ51T
Post Posted: Sun Dec 23, 2012 9:30 pm
I had the right wire, now it must be something else.
Vehicle: SWB Sierra
Post Posted: Mon Dec 24, 2012 11:45 am
What was the problem?
Vehicle: SJ51T
Post Posted: Mon Dec 24, 2012 7:14 pm
I don't want to say.
I had the accessories from the car to the constant on the stereo and the constant on the car to the accessories on the stereo :S
I am now +1 multimeter ;)
Post Posted: Thu Dec 27, 2012 8:49 am
X2
Tho if (you some how managed) to grab the high beam wire (constant power due to neg switching) the radio would turn off when the head lights come on...
So run through all accessories just to check that it is a true constant.
Users browsing this forum: No registered users and 58 guests
