It is currently Fri Jul 31, 2026 12:03 am
Vehicle: In the market
Post Posted: Tue Dec 25, 2012 6:14 pm
Hey guys sorry to be a noob new to 4x4ing and curious to know what I need to buy to complete a 2 3 or 4 inch lift in a jimny also what size tyress and what lift would you suggest?
Vehicle: 2012 jimny
Post Posted: Wed Dec 26, 2012 5:09 am
215/75/75 with no lift, trim a bit off front bar. 215/75/15 with 2 inch perfect. 235/75/15 with 3 inch seems popular on here. I got a 2 inch ironman lift and I doubt it's 2 inch as it's pretty high.
Post Posted: Wed Dec 26, 2012 7:57 am
What do you want to do with the car? What terrain do you want to drive? You need to thinking about gearing for anything bigger than 225/75s. 235s fit with no lift on 15x7 -13 rims with the front bumper chopped.
Post Posted: Wed Dec 26, 2012 9:25 am
Mainly sand an mud and a few tracks
Post Posted: Wed Dec 26, 2012 2:45 pm
215/75s with a 2" lift is what I'd do if that's all I was doing.
Vehicle: Suzuki Jimny 2010
Post Posted: Thu Dec 27, 2012 10:10 pm
X2 :)
Post Posted: Mon Dec 31, 2012 3:50 pm
Springs, Shocks, Panhard Rods, Castor correction of some sort (bushes or new arms), extended brake lines (depending on lift)
jimnybits is popular have a look there.
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Jan 02, 2013 10:11 pm
Wouldn't I be better off with a 75mm or 80mm lift if I wanted to get into some offloading or is a 2 inch lift enough..? Eventually I'd like to get lockers snorkel mud tyres winch etc..
Post Posted: Thu Jan 03, 2013 1:04 am
2" will be fine. When you go to 60mm of lift or bigger you start to need adjustable panhard rods, castor bushs etc... So the money saved on the lift put that towards lockers as that will take you further than another 1" of lift.
Post Posted: Thu Jan 03, 2013 2:07 pm
Ok im going to get lockers either way, what's the best size wheels to run with a 3" lift with a standard auto box?
Vehicle: 2000 suzuki jimny
Post Posted: Thu Jan 03, 2013 8:34 pm
im running a 2" dobinsons lift with shockers to suit and 31s....... BUT i got my grinder out and chopped the guards and chopped and tucked the guards that with the engine conversion i did can not be touched on the beaches patrols and cruisers are bogged to there guts and i pull up park next to them and drive off again and only leave my tread pattern in the sand its mean BUT i want the off road armory lift kit it costs a bit but its got everything you will need and FLEXES NIIIICE it with a 2" body lift and im going to be a very happy man
Post Posted: Thu Jan 03, 2013 8:43 pm
Why lift the car more than you need to? 4" suspension lift and 2" BL is that your goal? Low is the new lift.
Post Posted: Thu Jan 03, 2013 8:50 pm
X2
I have the 4" lift and its HEAPS high enough!!!
Vehicle: 2011 jimny
Post Posted: Thu Jan 03, 2013 9:18 pm
i wish my 2 inch lift wasn't so high :? measured it toady turns out its 4 inches higher than stock ... :roll:
Post Posted: Thu Jan 03, 2013 9:20 pm
how are you guys measuring the eyebrow height, from the centre of the hub?
Vehicle: 2011 jimny
Post Posted: Thu Jan 03, 2013 9:22 pm
yeh to the highest point of the wheel arch
Post Posted: Thu Jan 03, 2013 9:25 pm
:shocked:
Post Posted: Thu Jan 03, 2013 11:21 pm
I'm thinking il get a 3 inch kit what brand kit would use suggest? Also Wat size tyres with standard auto box.
Post Posted: Thu Jan 03, 2013 11:32 pm
what this guy said...
:rofl: hahaha i just worked out jimnys are gay... gearing required for a 28.3" yet a vit can deal with a 30-31. :thefinger:
Users browsing this forum: No registered users and 92 guests
