It is currently Wed Oct 28, 2026 11:47 am
Post Posted: Tue Jan 01, 2013 2:55 pm
My current manifold has a stripped out thread in it, so I bought some hurricane extractors for it, but I'm a little worried about heat they can generate. So I've come looking for advice on exhaust wrap, does it actually work for preventing heat? Does it make the extractors rust quicker? Any other pro's and con's?
Cheers :D
Post Posted: Tue Jan 01, 2013 3:13 pm
get them ceramic coated, le google high performance coatings for someone near you
Vehicle: sj51
Post Posted: Tue Jan 01, 2013 3:48 pm
And make a heat shield
Vehicle: '96 LWB trayback
Post Posted: Tue Jan 01, 2013 4:00 pm
I exhaust wrapped my old extractors. The heat reduction was epic. You could lean against them after hard driving and they were barely warm.
Unfortunately the extractors rusted through after 18 months. The wrapping had captured all the moisture, mud etc and trapped it.
For this reason alone I won't use the stuff on a 4wd again.
Make a heat shield to deflect the heat away from sensitive components and grab some dynamat to insulate the cab, bonnet and firewall.
Post Posted: Tue Jan 01, 2013 5:00 pm
Dynamat sounds good! Looks expensive tho... I would be running it down the passengers side fire wall and a little on the floor...
If the inside of the car gets wet, how do I dry underneath it?
Post Posted: Tue Jan 01, 2013 5:47 pm
i know i am not really located close to you josh but a mate of mine does ceramic coatings etc on turb manifolds n extractors etc and a heap of other bits and pieces
hes been at me for ages to pull mine off the zuk and get em done cos they are rusty as
Post Posted: Tue Jan 01, 2013 5:57 pm
jaycar do a similar product @ $30 for a 900 x 330mm sheet & can do group buys :) http://www.jaycar.com.au/productView.asp?ID=AX3687
Post Posted: Tue Jan 01, 2013 6:39 pm
Is the Jaycar stuff as good as Dynamat?
Post Posted: Tue Jan 01, 2013 6:44 pm
If the jaycar product is still relabelled "brown bread" brand, It has a much stronger smell and less tackiness than dynamat, especially when exposed to water.
Josh: I've got double layers of dynamat xtreme on my passenger side floor and firewall. And a single layer inside the remainder my my entire cab. Floor and firewall also have a layer of dynaliner over the top.
It's enough to step any feeling of heat from my exhaust.
I've drowned the car a couple of times in fresh water since applying it. I cut a section out to inspect the floor a few months back, there was no sign of any retained water.
It's all about how well you roll it in the curves to seal it. You can also get dynatape to seal the edges if you're paranoid.
I spent a few years as a pro audio installer at a reputable workshop. After using most brands available dynamat is the only one I'll recommend.
Post Posted: Tue Jan 01, 2013 8:50 pm
Dynamat it Is then! I'm guessing repco/supercheap type shops sell it...
Hey matt, how much would your mate cost to ceramic coat my extractors?
Post Posted: Tue Jan 01, 2013 8:52 pm
good to hear actual feedback, i've used the jaycar stuff in small sections great with success. haven't used the dynamat stuff though, would be nice to do a whole cab. 8)
Post Posted: Tue Jan 01, 2013 8:58 pm
Haha yeah, I was looking at a set of 30x9.5HT's the other day to cut down on tyre noise...
But to be honest, who knows, I might never even feel there is a difference In the heat and this could of all been for nothing :lol:
Post Posted: Tue Jan 01, 2013 9:00 pm
i want to do the insides of my rear wheel arches, the drawers in the shorty did a pretty good job of quieting the hum of the tyres down.
Vehicle: Suzuki Jimny 2010
Post Posted: Wed Jan 02, 2013 7:35 am
I never had a problem with them heating the cab, the engine bay and anything in the surrounding area used to cook. There's a black line on my radiator overflow from where it heated up and he ac line was pressed against it :shocked:
I reckon a decent heatshield in the engine bay (not as dodgy as mine ;) ) and maybe ceramic coating them and you'll be fine :)
Post Posted: Wed Jan 02, 2013 11:45 am
That's another thing I guess, stopping the heat well before it gets to the body. Kinda like an inner-Vs-outer sun protector on a windscreen.
Post Posted: Wed Jan 02, 2013 11:58 am
ill ask him anyways josh and let you know so you can compare price or send em here or whatever
Post Posted: Wed Jan 02, 2013 5:40 pm
Okay, thanks :D
Users browsing this forum: Google [Bot] and 304 guests
