It is currently Tue Nov 03, 2026 8:42 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
Post Posted: Fri Dec 07, 2012 8:42 am
2 x ARB Airlockers - $1200ea
One is a RD88, very rarely used as it is in the front. Probably has seen around 500klms in this car since it was put in.
The other is a RD208, installed by ARB in August 2012. Has done 1 comp, wouldn’t have even done 100km’s.
Both are basically brand new and fitted to 3.9 centres. All bearings were done at install of both lockers.
1 Pair of Sierra Chromo CV’s - $150 - Sold
Installed the same time as the RD88 and has had the same usage.
Set of Vitara LWB front Calipers and rotors - $150 - Sold
Used but good condition. I never got to use them as they scrubbed on my wheels.
Set of Double Black Offroad Flares - $350
These are the flexible round flares sold by Double Black. Brand new, never been fitted.
G16a with Ben T conversion kit - $700 package
Package includes extractors, VL commodore engine mounts, Ben T conversion kit and G16a engine. Everything you need to put it straight into a Sierra. Viscous hub on the front has just been reoiled.
Jimny Powersteering Set up - $450 - Sold
Works flawlessly pushing 31” Silverstone Extreme’s around at 4psi. Includes pump, reservoir, lines and box.
Vit LWB Alloy Radiator - $150
Brand new still in the box. Bought it to keep the G16a a lot cooler but never installed it.
G16a Torque Camshaft - $100
Reground camshaft to suit G16a to increase engine torque. Never installed personally so I don’t know how it performs.
JC’s Transfer Lift Kit - $80 - Sold
Never installed, still in the bag
JC Body Lift - $100
Has been in the car for a couple of years. Removing to get the car lower.
6.5 Transfer Case with Ben T Transfer Arms -$850
Recently rebuilt case – Approximately 300km’s since rebuild. The Ben T arms are great for distributing load.
6.5 Transfer Case - $600 - Sold
Condition unknown. I’ve never run this case, was purchased to run as a spare but never broke the first one. Handbrake on the back needs attention or removal if going in a WT. Might need a shifter bush.
JML Floater Kit with brakes - $800
This is the bolt on JML floater kit with the correct callipers, rebuilt 100km’s ago, brand new vitara rotors, fresh bearings in the hubs, with spindles and GV solid flanges. This stuff cost a lot to get together and has had barely any use.
Spare set of GV Solid Drive Flanges - $80 - Sold
End cap on one is damaged but that does not affect the performance.
Front and Rear GV 4.3 R&P Gear sets - $150ea or $250 for both - Sold
Either run the front in a sierra or for those wanting gearing and going full floater vit rear, as was my intention, run both for decent gearing.
Front Vit 5.12 R&P - $100 - Sold
Still in alloy diff, can supply the whole thing or just the R&P.
TSOR Chromoly Steering Arms - $450 - Sold
Hardly used, don’t think they are even scratched. Great steering arm upgrade.
2 Sets of 4 31” Silverstone Extreme’s - $800each set
Both are around 80-90% tread. Currently on rims but will be sold without
4 Black 15x7 Rims - $150 set
Unsure of brand, I think around a -13 offset but can’t confirm until I can get to the rims again.
Sierra Gearbox - $100
Used but good condition. No grinding in any gears and has tight shift. Approx 220 thou km’s
SWB Driveshafts - $60ea
Front and Rear Sierra SWB driveshafts. Same k’s as gearbox. Uni’s replaced 500km’s ago.
TSOR Fuel Tank Guard - $100
Has rock rash. Solid dint in the back but not bad enough to touch the tank.
Standard Fuel Tank - $50
No leaks, don’t recall any dints but it probably has a few small ones.
WT rear diff housing on NT mounts - $70
Has been shaved by a previous owner.
AVM Heavy Duty Freewheeling Hubs - $80 pair - On Hold
Have had them on for a while with no problems in the front end.
May be more to come – pretty much most of the car except the chassis, some of the body and the cage will be parted out.
Note I’m currently out of town so I may not be able to do pictures in a rush. If interested in any parts contact me and I’ll see what I can do. All parts currently located in Rockhampton, QLD.
Post Posted: Fri Dec 07, 2012 10:39 am
I'll take the Pair of Sierra Chromo CV’s - $150
Just need to work out to get them to Brisbane.
Pm me when you get time and we can work out payment and Transport. :-)
Vehicle: Daisy
Post Posted: Fri Dec 07, 2012 3:51 pm
I'd like the jimny powersteering setup please. $450
I'm on the Gold Coast 4218, happy to bundle together with someone in GC or Brisbane if it will make our freight cheaper and I can just meet up with them for pickup?
Tim
Post Posted: Fri Dec 07, 2012 5:02 pm
Done Bruce :D
Power steering also sold pending payment
Post Posted: Fri Dec 07, 2012 5:32 pm
What's the tank guard worth posted to sale 3850 victoria
Vehicle: MG410 Gypsy
Post Posted: Sat Dec 15, 2012 12:55 am
Have u sold the chromolys?
Post Posted: Sat Dec 15, 2012 5:52 pm
hey mate i will take 5.12 r&p if reasonably priced shipping to vic?
Vehicle: 92 Sierra bars F&R locked
Post Posted: Mon Dec 17, 2012 6:26 am
Is the fuel tank guard still for sale?
Post Posted: Mon Dec 17, 2012 7:50 am
Redrockets is first in line for the fuel tank guard depending on a frieght price.
Which chromolys? CV's are spoken, rear axles and steering still available.
Bozzaa I'll send you a pm.
Post Posted: Mon Dec 17, 2012 9:17 am
If he doesnt get the tank gaurd ill buy it.
Vehicle: 1991 Vitara SWB
Post Posted: Fri Dec 21, 2012 11:08 am
How high is the body lift kit?
What's it made out of?
Post Posted: Fri Dec 21, 2012 11:09 am
2". It's a Just_Cruizin kit so it is a poly of some sort but not sure on exactly what it is.
Post Posted: Fri Dec 21, 2012 9:47 pm
Polyeruthane 75D, same product is used in crane baseplates. Incredibly durable product.
Post Posted: Mon Dec 24, 2012 6:40 am
Has the fuel tank guard been sold yet?
Post Posted: Mon Dec 24, 2012 12:20 pm
Thanks, I'll think about it... For some reason poly body lift kits aren't legal in Vic.
Post Posted: Tue Dec 25, 2012 8:15 pm
...and they're the only ones legal in NSW. Go figure. :roll:
Vehicle: 96 coily Awesome sticker Rust
Post Posted: Tue Dec 25, 2012 8:24 pm
PMed Motor Trans case
Vehicle: Ratio's, Twin Locked Sierra
Post Posted: Fri Dec 28, 2012 8:51 am
Do you still have the flares
Post Posted: Fri Dec 28, 2012 1:39 pm
PMd about the cam.
Post Posted: Fri Jan 04, 2013 12:38 pm
All pm's replied too I think, if I've missed anyone just let me know. I apologise for the delay, I've been quite sick recently so haven't been able to do things as fast as I would have liked.
Post Posted: Fri Jan 04, 2013 1:04 pm
No worries Zook_Fan, just PM me when ya ready to work it out :-)
Vehicle: Daisy
Post Posted: Fri Jan 04, 2013 3:16 pm
^^^ Same, I've got cash ready to transfer when you let me know postage cost :) Good luck with getting better mate!
Vehicle: 93 sierra, 1600twincam
Post Posted: Fri Jan 04, 2013 5:10 pm
just making sure the power steering is gone?
Post Posted: Fri Jan 04, 2013 5:28 pm
darkhorse has a complete vit power steer set up that he's looking at off loading. viewtopic.php?f=7&t=37563&p=696385#p696385
Post Posted: Fri Jan 04, 2013 5:35 pm
Yeah sorry it's as good as gone. I'd be hitting up Darkhorse
Post Posted: Sun Jan 06, 2013 7:54 pm
Kevin is a top bloke!!!
Post Posted: Mon Jan 07, 2013 3:41 pm
Whats your best offer on the spare flanges and shipping to Brisbane?
Post Posted: Mon Jan 07, 2013 3:44 pm
They're sold pending payment clearing. I'll update the post tonight with what is sold and what is still here
Vehicle: SJ50 hardtop!
Post Posted: Mon Jan 07, 2013 4:41 pm
Still waiting on a freight quote for the rear diff if you still have it.
Not too fussed if it's sold though.
NT SJ50
Vehicle: SJ413 WT
Post Posted: Mon Jan 07, 2013 9:03 pm
PM'd WT Rear Diff
Users browsing this forum: No registered users and 18 guests
